Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-04-2007, 03:17 PM
sl9mk is starting off with a positive reputation.
Rear sump 460 or 429
Well, I didn't do the rear sump mod when I put my 460 from a Lincoln into my pickup. Consequently, I banged up my oil pan badly enough that I leaked out my oil and believe I have spun a bearing. This is fine because the motor is getting tired anyway.
My question: are there any rear sump 460's or 429's that would be a direct drop in? I have a 1973 F100 Ranger that I have converted to the Duraspark II electronic ignition (thanks to those of you who helped with that). It will be bolted to a C6. Yes, the truck is 4x4. The motor that is currently in it is from a 1975 Lincoln Continental. I really don't want to get crazy with changing motor mounts, headers, etc. If there any such of these animals out there, what years and in what vehicles?
Thanks! Shane
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-04-2007, 05:25 PM
monsterbaby's Avatar
monsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant future
the 80s model 460s from vans, or 4x4s has the rear sump pan, but you can buy the pans, and pickups from ford new still so it's not a big issue. Only other thing is if you switch from a front to rear sump pan you will also need the rear sump oil pump.
Also keep the flexplate with the motor, the 79 and later motors are external balance, the earlier motors are internal so the flexplates are not a direct swap (although they will bolt on, but it will affect the balance adversely)
__________________
Dying's not so bad
It's living that will kill you off
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
