2006 F150 Electronic Brake Controller - Ford Truck Enthusiasts Forums
Old 02-04-2007, 12:15 PM
NELawnCare NELawnCare is offline
NELawnCare is starting off with a positive reputation.
Hi folks,
I'm embarrased not to understand this, but have come to you guys for advice. I may be using the wrong terminology but I'll try to get my points/questions across.
I have a new F150 4x4. I am also buying a 14ft tandem trailer with brakes. The truck came with electronic trailer brakes, so I am told. I have a small bag with a wiring harness about 14" long and a trailer tow relay switch/plug.
I'm trying to decypher the installation instruction from Ford. The instructions are a measley 3 page graphical story with little words. I looked under the dash of my new 150 and I see where to plug the one end of the wiring harness into the molded 6-way gray wiring connector. But I have no idea what to do with the wire-cut ends of the harness. Is there some device I still need?
Thanks in advance for all the help.
NELawnCare
Old 02-04-2007, 02:37 PM
whitecrystal1's Avatar
whitecrystal1 whitecrystal1 is offline
whitecrystal1 is starting off with a positive reputation.
You still need to get a break controller. Then you wire the pigtail into it and plug it in under the dash. The relay plugs into the fuse panel in the passenger floor kick panel.
Some guys mount them under the dash. I mounted mine here so I can reach it if I need to.
Old 02-04-2007, 03:34 PM
Outstanding. I finished researching the different types of controllers. I decided to purchase the TEKONSHA PRODIGY BRAKE CONTROL v2.6 FORD 94+ HARNESS. Looks pretty simple to install now that I understand all the pieces.
Thanks again for your quick reply and helpful information.
Old 02-04-2007, 03:54 PM
kd4crs's Avatar
kd4crs kd4crs is offline
kd4crs is starting off with a positive reputation.
If you purchase the prewired harness for your particular truck, all you have to do is plug one end in under the dash and the other end into the Prodigy and you are all done except for mounting the unit. That saves you from having to do the wiring.
Old 02-05-2007, 11:16 AM
Quote:
Yup. Sure did. The model I bought comes with the prewired harness for most modern trucks. Although I received a wire-cut harness with my Ford, the premade harness from the controller's manufacturer will be handy.
Thanks again for all the help.
NELawnCare
Old 02-05-2007, 08:13 PM
Ferguson65's Avatar
Ferguson65 Ferguson65 is offline
Ferguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant future
Good choice on the Prodigy. I have a gallery with some pics of where I mounted my brake controller (Prodigy). Like whitecrystal1, I also wanted to mount it where it was reachable, but I don't have the console like he does. Lots of people mount them under the dash, but if you need to use the manual lever, you'll hit something while you're trying to find it!
Old 02-06-2007, 04:00 PM
tooldad tooldad is offline
tooldad is starting off with a positive reputation.
Has the dash angle been a problem with operation? I ask because the Prodigy specifies an angle less than 70 degrees (including any vehicle angle/grade), while I measure the dash at ~65-67 degrees. I mounted mine below the dash, but really wanted it higher for the reasons mentioned above.
Old 02-06-2007, 06:03 PM
No problem with the angle on mine, but mine has a lever (dial) on the side to offset the angle. I think you'll be fine with yours as well.
Old 02-06-2007, 07:07 PM
Ferguson65's Avatar
Quote:
If you don't have the console, check my gallery, there's about zero angle where I put it. It's still within easy reach, but out of sight unless you look real hard.
Old 02-07-2007, 10:44 PM
Ferguson65,
I thought about that location as well. It is currently mounted below the dash on the left side attached to the metal plate located there. Not the most convenient, but no real problems either.
Old 02-08-2007, 08:56 PM
Ferguson65's Avatar
I used that for my hidden "deactivation" switch for my driving lights on the bullbar. Since I don't have them wired "legally".
Wiring a Trailer Tow Battery jonesn4fun Electrical Systems/Wiring 1 10-24-2011 08:06 PM
*SOLVED* 00 Excursion: No power to some of trailer plug terminals fordtrkpuller Excursion - King of SUVs 11 07-17-2011 11:16 AM
1990 factory trailer brake harness question firewood truck Electrical Systems/Wiring 2 06-02-2011 10:30 PM
Electric Brake Controller and '79 Trailer Special Wiring Harness FordTrucksKickGM Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 1 01-09-2008 04:25 PM
Electric trailer brake wiring/dash wiring MustangGT221 1987 - 1996 F150 & Larger F-Series Trucks 30 08-10-2006 08:51 PM
Tags
2006, attach, brake, contollers, controller, electronic, f150, ford, hardness, install, oem, tekonsha, trailer, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
