V8 running on 4 - Ford Truck Enthusiasts Forums
V8 running on 4
Old 02-04-2007, 07:25 AM
Hayixer Hayixer is offline
Hayixer is starting off with a positive reputation.
V8 running on 4
Hi newbie here straight in with a problem !
I have a 98 Ford Econoline E 150 Day Van with a 5.4 V8 Triton Lump, 65000 miles , had it now for 3 years with no probs, but over the last month it has been starting every time but it is not fireing up on all cylinders (feels like 4, smooth ? )i have to keep my foot on the gas to keep it running, then after a few minuites it all fires up & runs fine until the next day when it does it all over again.
Now, for the last 4 days it will start up straight away & stay running on what seems to be only 4 pots (as long as i keep my foot on the gas) but will not fire up on all cylinders, i have tried it at all times of the day but Ziltch !! which has now put me off the road
Anyone have any answers ???
Cheers, Bob.
Old 02-04-2007, 02:31 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Welcome to FTE Bob
I've moved your question to a more specialized forum for you. You should get more answers here.
How many miles on the spark plugs and fuel filter?
Old 02-04-2007, 02:39 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
I would check the fuel pressure on start-up. This can rule out a fuel pressure problem.
Old 02-05-2007, 02:27 AM
Cheers Racerguy, smoothest move i've ever had.
Engine has now covered 65 thou, at last service i was told plugs will not need changeing untill 100,000 miles. Just checked my service invoice & the fuel filter was not changed !!
Hi Lx , how do i check fuel pressure on start up ??
Would low pressure only cut half the cylinders ? & then after 2 to 5 mins of keeping it running with the lightest of foot skill all of a sudden fire up & run like a dream all day long ?
Thanks for the fast replys guys.
Old 02-05-2007, 06:43 AM
Joe Finn's Avatar
Joe Finn Joe Finn is offline
Joe Finn is gaining momentum as a positive member of FTE.
If you need to keep your foot on the gas to make it idle, it might be the IAC (Idle Air Control). The IAC is on top of the throttle body. You can change it in about 20 min.
Old 02-05-2007, 12:57 PM
Hi Joe, will check the IAC, but Its not only to keep it idleing i can rev it to full revs it will still only be running on what seems to be 4 .
Would 1 or mabe 2 of the coil packs failing cause the ecu to cut fuel to one half of the engine ????
Old 02-05-2007, 01:56 PM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.
Failing coilpacks will not cause the EEC to cut fuel-it's possible that you've got some bad COPs,COP boots,or a combination of both. It's also possible that you got other mechanical issues-spark plugs being one of them-at 60K miles-I'd bet that they really need changing.
JL
Old 02-06-2007, 09:09 AM
Ok people thanks alot for all your help went throu every thing i could today & it turned out to be what Joe said the IAC. Its now running like brand new, nice one.
Next week is going to get a full service plugs, fuel & air filter, oil change & filter & any thing else i can think of including a new idle air control oh & i might even give her a go faster wash 'n' polish.
Old 02-06-2007, 01:06 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
If you are going to do plugs I'd replace the COP boots at the same time.
Old 02-06-2007, 01:23 PM
Will do....
99 E350 5.4 tritian starting problem flyinghi3 Modular V8 (4.6L, 5.4L) 3 01-28-2012 02:34 PM
POS 1996 FORD F250 bc18 1987 - 1996 F150 & Larger F-Series Trucks 13 11-07-2010 01:43 AM
1989 F250 460 Starting problems- Need help! probie 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 02-03-2009 04:00 PM
engine stalling out FFemt5287 Explorer, Sport Trac, Mountaineer & Aviator 3 08-23-2007 06:20 PM
1989 3/4 ton E-250 problem Heavy460 1968-2013 Full Size Vans 12 06-01-2005 05:43 PM
Tags
46, cylinders, f150, feels, fuel, on45, pressure, running, v8, v8triton
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
