How to reattach rear defroster connector tab(s)??? - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Old 12-26-2002, 07:23 AM
Steve0 Steve0 is offline
Steve0 is starting off with a positive reputation.
Hey there, I found out why my rear defroster isn't working. At first I thought it was the dash switch but upon closer inspection, I had found that one of the tabs that is on the defroster grids had popped off.
I was wondering if anyone knew what kind of compound/glue I can use to reattatch it? I tried solder but it didn't work, it just rolled off. It looks like it was stuck on with some lead-looking-metallic compound and I was wondering if plain ol super glue would work...but then again I woulda thought it would have to be able to conduct electricity in order to get power to the grid. Maybe just a dab on each side of the tab will work, or do they have special compounds for this kinda stuff?
If anyone has any experience or thoughts on this I'd be happy to know.
Thanks.
Steve0
Old 12-26-2002, 09:11 AM
AlM's Avatar
AlM AlM is offline
AlM is starting off with a positive reputation.
sent you the repair kit by message here; I think the store in FTE here had a similar kit last month.
Old 12-26-2002, 12:17 PM
steve83's Avatar
steve83 steve83 is offline
steve83 is starting off with a positive reputation.
It is soldered, but you have to be VERY careful when heating the glass or it'll shatter. Super glue is acrylic, which is an EXCELLENT electrical insulator - don't do it. Don't use any glue.
Old 12-27-2002, 04:31 PM
galaxiefiveohoh galaxiefiveohoh is offline
galaxiefiveohoh is starting off with a positive reputation.
Old 12-27-2002, 08:41 PM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
Steve,
All too true! I resoldered one to my rear glass when I did the tailgate replacement a few months ago. Unless you have the experience and knowledge of solder techniques, be very careful if you attempt to do this repair. Tempered glass is about as predictable as my wife. The tabs MUST have a strong "conductive" bond to the defroster on the glass.
Old 12-28-2002, 12:18 AM
mrwizard's Avatar
mrwizard mrwizard is offline
mrwizard is starting off with a positive reputation.
Mine had the same problem. Before I could get around to fixing it, the whole metal strip that runs along the bottom of the window came off. I always hoped somebody would break the back window so the insurance would spring for a new one. Never happened though.
Anyone tried compounds? HAMMERDOWN103 1999 - 2003 7.3L Power Stroke Diesel 16 01-29-2013 08:33 PM
Presidential Solution for Harness Repair! pmasley Electrical Systems/Wiring 1 02-19-2010 11:04 PM
Rear view mirror metal tab won't come out 6CylBill 1987 - 1996 F150 & Larger F-Series Trucks 22 06-30-2009 09:53 AM
No Rear Window Defrost ? ckutter Expedition & Navigator 3 09-25-2008 04:20 PM
Rear Window Defroster Repair dukman22 Expedition & Navigator 0 10-23-2006 06:31 PM
Tags
1998, bronco, defogger, defrost, defroster, glue, metal, mustang, rear, reattaching, repair, replacing, strip, super, tab, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
