Is the intake for a 4.6L the same as a 5.4L? - Ford Truck Enthusiasts Forums
Old 02-03-2007, 10:28 PM
TX76F250 TX76F250 is offline
TX76F250 is starting off with a positive reputation.
Not real familar with the Ford "modular" engines and what interchanges between the 4.6 and 5.4. It seems that I have the dreaded coolant leak from the crossover tube on the 5.4 in my '99 Expy. I'm handly enough with the wrenches so after looking over the procedure, I'm gunna give it try. So I've been poking around and haven't had much luck ID'ing a replacement intake. I have come across a couple that were listed for a 4.6 and that's what has brought this question up.
The rig has 112K on it and other than this leak and a couple other minor 'tweaky' things, it runs great!!
Thanks in advance!
Scott in Texas
Old 02-03-2007, 10:54 PM
phil6608's Avatar
phil6608 phil6608 is offline
phil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant future
No,the 4.6 and 5.4 are not the same.They look the same but the 5.4 is a taller block therefore the 5.4 intake is wider then the 4.6.
I have a 5.4 intake off of my 03 if you need one.
Took it off when I did a Lightning conversion.
Phil
Old 02-03-2007, 11:07 PM
Wow...Thanks for the quick reply, Phil! I appreciate the offer on the intake. PM me and we'll work out the details.
Old 02-04-2007, 09:07 AM
rsylvstr rsylvstr is offline
rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.
Phil
really?
the one I took off my 2001 F150 5.4L has the ford sticker that says 4.6/5.4L so i would've thought they were the same.
if anyone else needs the stock setup, let me know....i put the K&N Series 77 intake on mine.
Old 02-04-2007, 09:26 AM
phil6608's Avatar
Quote:
Originally Posted by rsylvstr
really?
I think hes talking about the intake (manifold)!
The air intake may very well be the same.
Phil
Old 02-04-2007, 10:20 AM
Phil
you are 100% correct....my bad. thanks brother.
FOMOCO recalled the 4.6 L engine in my truck and replaced it with a 4.6?? long block wes97FT Modular V8 (4.6L, 5.4L) 2 10-10-2011 02:06 PM
5.4L to 4.6L swap question wpiccian 1997 - 2003 F150 25 04-13-2011 07:19 AM
mod motor for 56 f100 project, 4.6 or 5.4? sdetweil Modular V8 (4.6L, 5.4L) 8 07-07-2009 11:14 PM
F150 4.6 Tuning 720Deere Computer Chips & Tuners 5 11-13-2007 08:41 PM
How Difficult is it to change plugs in a 4.6L? Skywalker1980 1997-2006 Expedition & Navigator 2 01-23-2004 04:08 PM
Tags
2007, 46, 54, block, conversion, coolant, crossover, ford, intak, intake, intakes, lariat, lighting, manifold, modular, regular, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
