Whistling Noise When Cold Outside - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 12-18-2008, 12:39 PM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to behold
Quote:
Originally Posted by mwmod97m View Post
I have an 05 with a 5.4 and it just started doing this couple nights ago while it was -20 degrees. Looks like many here are experiencing different whistling problems. This whistling is not in the alternator, as it does not do it if the pickup is parked.
Its the alternator.....thats it does it for all of us...it must have something to do with when its under load and at certain rpms.....
  #47
Old 12-18-2008, 12:43 PM
rmartens24 rmartens24 is offline
rmartens24 is starting off with a positive reputation.
It pretty much sucks that Ford doesn't take care of this alternator problem. Why is it that so many other vehicles don't have this problem? My battery is over 4 years old so I'm going to replace it with a new Interstate 1000 amp and 850 CCA this week. I'm curious if my battery is causing my alternator to work harder and cause this noise under extreme cold.
  #48
Old 12-18-2008, 12:58 PM
mwmod97m mwmod97m is offline
mwmod97m is starting off with a positive reputation.
Quote:
Originally Posted by rmartens24 View Post
I had my alternator replaced in 2007 for this problem and it fixed it until this week. My alternator also didn't make the noise while parked, but it made the noise at different speeds. My whistle is exactly as you explained and the tech says it is the alternator. I called a the Ford dealer that replaced the alternator and said it is the alternator and many people are coming in to have replaced. However, it eventually happens with the replaced one too! He told me that Ford is possibly checking in to the problem and they need to come up with a fix. I'm wondering if a guy puts in an aftermarket alternator??
Crazy stuff, nothing worse than whistles, squeels, squeeks, rattles, shudders, and vibrations. Man that kinda thing drives me crazy.
I will do an alternator swap with my dads 05 to test it before I dish out money for an alternator.
  #49
Old 12-19-2008, 01:48 AM
Ryan50hrl's Avatar
alot of 05's had the problem as well....it was a pretty common thing, they'd fix them under warranty...
  #50
Old 12-19-2008, 12:03 PM
Mr. F150 Mr. F150 is offline
Mr. F150 is starting off with a positive reputation.
I have 2005 f-150 super crew 4.6 4X4 with now 80,000km. I bought it used last year and I also have noticed this irrtating noise when the temp reaches below -10 and as I pedal the throttle the noise changes pitch. Had it at the dealer last year they couldn't find any codes or reproduce the noise, so they say. I tend to think either cold air coming into the intake or belt or pullies/tensioner. I hope either I or someone finds this problem. I have only ever had Fords ( trucks cars vans) and have never had this problem before. If I find it I will definately let everyone know as I tend to brag my Fords all the time till they hear the noise and I cheapestly say didn't do that before..
  #51
Old 12-19-2008, 01:00 PM
bob schulz bob schulz is offline
bob schulz is starting off with a positive reputation.
Mine whistled too.......
'04/150/XL, 4.6 L, 12K per year, noted whistling first winter at about 55 mph at 10 degrees or colder and I could modulate the sound by slightly changing the throttle?!
I was shocked as it was a new truck but as soon as the outside temp. rose, the sound went away. I know it was not the alternator because I never did anything about it and the alternator is fine, the truck still runs fine today, and this winter I have yet to hear the noise, four years later.
I think conditions such as relative humidity, temp., dew point, and others I don't know of may contribute to the noise within the intake system. If, however, something breaks and after I fix it the noise never occurs, I'll know what the problem was. Great trucks these Fords, I really have no complaints. I'm 62 and I figure unless it breaks I'm gonna drive, observe it, and when it gets bad, fix it.
Every morning I wake up and ask, "Why me God?, why am I so fortunate to have been born in the greatest country in the history of humankind and to be driving a Ford pickup?" Have a Blessed Christmas everyone.
  #52
Old 12-19-2008, 04:51 PM
Ryan50hrl's Avatar
To everyone posting on here....its a VERY COMMON problem...and everyone of them that i've seen, heard about, or talked to anyone about it solved it with an alternator....the truck will still run fine...the alternator will probably last you 100,000 miles or more without ever replacing it....but seriously...if it annoys you that much....go have it replaced or rebuilt with ALL new parts....take it from those of us who had our trucks in 10 times, overnight, in bitter cold weather to get to this diagnosis....ITS YOUR ALTERNATOR
  #53
Old 12-20-2008, 11:44 AM
Big-Red-Lariat's Avatar
Big-Red-Lariat Big-Red-Lariat is offline
Big-Red-Lariat is starting off with a positive reputation.
amen. New alternator cured mine after many belt lubes, belt change and other f'ing around.
  #54
Old 12-21-2008, 07:43 PM
vpsr6 vpsr6 is offline
vpsr6 is starting off with a positive reputation.
I was going to create a new post but saw this one on the very same issue I have started having. I have had my s cab 5.4 since new and have never heard any whistling,squeling or anything like that until last weekend I installed a new Roush Billet style grill. First ride after the install as soon as I got to 60mph I had this whistle kind of like a coaches whistle let off the gas goes away get back to speed comes back same exact situation at 70mph. I think it's the gap between the grill surround and the hood. With the Roush I noticed a bit of a gap versus my stock which was totaly flush. Wind passing over that gap could certainly cause the whistle, I think that is why some people can not duplicate it standing still at the same rpm etc... I just think it would be a bit to coincindental for anything else to be the culprit. I plan on trying to put something in the gap to see if it's that or not. It could be possible for some stock surrounds to have a gap as well.
thanks
  #55
Old 12-22-2008, 04:07 PM
Rudeman's Avatar
Rudeman Rudeman is offline
Rudeman is starting off with a positive reputation.
My 2005 5.4L does it in park as well as when under way but only when it is below 30F. Usually it is triggered by subtle changes in engine RPM. AND...I have had an aftermarket grille insert since I bought the truck in April '08 and it was quiet until just recently when the temp took a dive. I'm calling the dealer to have it looked at.
  #56
Old 02-16-2009, 11:18 AM
tula771 tula771 is offline
tula771 is starting off with a positive reputation.
TSB-08-4-2
Cold Start Fead Hoot-Whistle Noise-built before 1/c
Pub. Date Feb 7, 2008
F150
5.4 and 4.6 engines built before 1/28/08 may exhibit a front related high pitched metallic whilstle/hoot noise after a cold soak 4.4 C. Noise may be caused by the grooved nylon FEAD idler plly.
Service procedure to correct. Replace the nylon FEAD idler pully 6L3Z-6C348-A Idler Pully.
I have this problem this winter in Michigan on very cold days, 10 degrees F and colder. I hear it at about 40-45 mph, and 65-70 mph. I thought my alternator was going to blow up. I have not got it fixed yet, now its in the 20s and does not make the nose. But NOW I know the problem.
Whistling noise ??? big-head 6.0L Power Stroke Diesel 3 10-23-2015 03:07 PM
Whistling Air Noise Heard with Vent Functions LARIAT 85 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 20 06-08-2013 01:45 PM
Turbo making whistling sound? monwv04 6.0L Power Stroke Diesel 13 04-07-2011 09:45 PM
2006 Ford F-150 Whistle? Shaunjr_89 2004 - 2008 F150 5 01-28-2011 01:37 AM
Whistling Noise After A/C Repair SeannyBoy84 Cooling, Heating, Ventilation & A/C 1 05-30-2006 06:30 PM
Tags
2004, 2008, 2l1z9w548aa, airraid, assembly, cold, explorer, f150, ford, hose, mit, motor, nipple, noise, weather, whistling
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
