Power mirror schematic? - Ford Truck Enthusiasts Forums
Old 02-03-2007, 01:58 PM
Timgeorgi Timgeorgi is offline
Timgeorgi is starting off with a positive reputation.
I'm trying to find the wiring diagram for the power windows in a 96 f150. I've got a set of these that i need to fab a harnes for to install in my 82. If anyone could scan and post a pic or link that would be a great help. Thanks!
Old 02-03-2007, 03:40 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Here's a diagram for the windows.
http://www.autozone.com/images/cds/g...3d800a3a60.gif
Old 02-03-2007, 04:34 PM
i saw that schematic but, unless i'm missing it, there isn't any mention of the mirror wiring. Please let me know if i'm wrong!!. Thanks for the help!
Old 02-04-2007, 10:04 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Old 02-04-2007, 10:09 AM
Exactily what I was looking for! Thanks
Old 03-15-2007, 08:24 PM
subford's Avatar
Old 09-03-2010, 02:03 PM
CarvinAbuser CarvinAbuser is offline
CarvinAbuser is starting off with a positive reputation.
If anyone can repost the '96 F150 mirror switch pinout, I'd appreciate it. Thanks
Old 09-03-2010, 02:55 PM
subford's Avatar
1996 Power Mirror Diagram:
Switch Pinout:
Old 09-18-2011, 12:26 PM
ghettoscrap ghettoscrap is offline
ghettoscrap is starting off with a positive reputation.
C'mon MODS or Users, if the info is not available delete the whole freaking post! it does absolutely no good to anyone, anywere to NOT have the pictures or links operable to a forum post, especially one as technically relevant as this one!!! maybe it should be a sticky in the archives, I know I am not the only one doing this mod!!!!
I need this info to install a set of 1996 power mirrors on my 1992 Bronco and would love to have some schematics to build a layover harness from the one I yanked out of the '96. I can do everything but I had to cut the harness near the big a$$ aluminum support that the brainiacs at Ford stuck RIGHT IN THE WAY OF EVERYTHING under the dash. I am not sure were to tie this in at or if it has its own leads to the fuse block.
C'mon FTE, help a fellow Ford lover out here and I will PERMANENTLY keep these schematics archived on my personal website, in fact, I have so many of these Ford trucks, I will archive and make available ANY and ALL schematics, diagrams and any other info for the 80-97 F-series that you cats send me. It will be an OBS repository if you will. WHY? because I am tired of searching for info just to find the links, or pictures are NOT there anymore.
Thanks for letting me vent.
Old 09-18-2011, 08:21 PM
Franklin2's Avatar
Welcome to the internet. It's ever changing, and people and companies are always changing their websites. So that's why there are always dead links in old posts. This post is almost 4 years old.
I will give you some tips that work about 75% of the time for me when I am looking for info or doing research and hit dead links.
1. Look at the dead link very carefully Copy and paste it so you can look at the whole thing.
2. Then you can dissect the link and possibly figure out a way to it. Let's use the above as an example.
The above link is i54.photobucket.com/albums/g91/subford/Electrical/1996PowerMirror.gif
This is pointing directly to a specific page which has probably been moved, but may still exist. Most of the time if you go back through the front door of the website, you can find the page still exists. In this case we know the picture was at the photobucket site.
So I plugged in the photobucket site and went to the front page. I then studied the url above some more, and noticed in the url was the name "subford" and this is also the user name of the guy who posted the link in the first place. So in the search box on photobucket's site I typed in "subford". Not much info came up, so I started clicking around and on the right of the page was a link "view subford's profile". I clicked on that, and it took me right to his albums which still exist.
It will take some time searching through his albums, but this diagram you want might still be in there. I didn't look for it, but looking at the original url, he had a folder called "electrical". I would see if that folder still exists.
This method will work for most dead links that are hosted by large sites. Unfortunately if you run across a link to someone's personal website, sometimes you try to go to the front door of their site and the whole thing is gone. If that happens, you are usually sunk.
Old 09-19-2011, 06:49 AM
subford's Avatar
Email sent to ghettoscrap with links to diagrams.
Old 02-19-2013, 07:17 AM
cowboyteddybear cowboyteddybear is offline
cowboyteddybear is starting off with a positive reputation.
I would like this info im thinking of doing this to my 92 f350
Old 02-19-2013, 07:44 AM
subford's Avatar
Quote:
The above two images.
Power Steering pump filter Roger C 1961 - 1966 F-100 & Larger F-Series Trucks 2 02-16-2017 09:57 AM
No power to rv plug Trath67 2017 Super Duty 6 12-18-2016 04:23 PM
What is that valve? power-power Explorer, Sport Trac, Mountaineer & Aviator 4 07-12-2016 11:13 AM
Power Liftgate Module? dalesatter 1997-2006 Expedition & Navigator 0 06-12-2010 12:34 AM
POwer steering and brakes hp loss? Rat wagon FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 10-23-2003 08:52 PM
Tags
97, diagram, drivers, f150, f250, f350, ford, mirror, mirrors, pin, power, schematic, side, switch, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
