Cruise Control - 2006 F250
Hello,
I am trying to find out if Ford's cruise control has gotten crappy, or if mine has problems in my '06 F250.
When I set the cruise, it goes about 3 MPH above what I set it at, then drops to about 3 MPH below, then it eventually stays where I set it. That is until I come to the top of an overpass or other small grade, then it is back to about 3 MPH over again as I reach the top and level out, then going back to where I set it.
The cruise control in my previous Ford trucks (83 & 91), as well as my 82 Mustang, 85 Lincoln, wife's 97 Toyota and the 2013 Chevy rental I just had, works fine. Where you set it is where it stays. Of course going up or down a steep grade, they all are going to lose or gain speed.
Anyway, I have taken the truck to the dealer twice for the cruise control. The first time is when I got the truck in '08. They replaced something else non-related, and said that would fix the cruise. It did help marginally, as the fluctuation was +-4 MPH before. I just took it in again before it goes off warranty, and they said the cruise is operating normally.
So, there's my story. Is this normal, or is something wrong? Thanks.
