stalling question - Ford Truck Enthusiasts Forums
stalling question
Old 02-03-2007, 11:27 AM
buttz buttz is offline
buttz is starting off with a positive reputation.
stalling question
I just got my truck back from getting the heads done. Now everytime I put it in reverse it dies, any ideas? its a 99 f250 superduty with a 5.4
Old 02-03-2007, 04:28 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Sounds like either a vacuum leak or the IAC isn't working.
Old 02-03-2007, 06:37 PM
even if its fine in drive?
Old 02-03-2007, 07:26 PM
LxMan1's Avatar
HMMM, it only does it in reverse. Unless a bare wire or something is hitting when the motor torques to the left when it goes into reverse. Other than that, a tranny problem is the only other possibility.
Old 02-04-2007, 10:55 AM
i double checked everything and in D N and P its fine but in R 2 and 1 it boggs down then stalls
Old 02-04-2007, 01:50 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Does it drive normally otherwise?
Old 02-04-2007, 03:41 PM
yes it drives fine
Old 02-05-2007, 08:34 PM
LxMan1's Avatar
Check the wiring going down to the gear position switch on the side of the tranny. Make sure it isn't hitting the exhaust or anything.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
