Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 02-03-2007, 09:18 AM
clydesride clydesride is offline
Garage is empty, add now
clydesride is gaining momentum as a positive member of FTE.
Pre-turbo pyrometer installation?
Hi guys, was reading about guages around here and wondered about the pre-turbo install.... how do you prevent chips of metal from getting into the manifold when you drill it for the pyro mount? I am planning to do the guage thing soon and was really wondering what was up?
Dave
__________________
2012 F-150 Supercrew EB, XTR trailer tow and locking 373 diff, etc. Had a 2002 Excursion, 7.3l, Limited, Dark Blue/Tan, 6637... RIP
  #2 (permalink)
Old 02-03-2007, 09:28 AM
guzzle92's Avatar
guzzle92 guzzle92 is offline
no leaks here...
2002 Ford F-350
guzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to all
__________________
guzzle
02 F350 4x4 SRW EC LB Lariat
guzzle's Mods & Maintenance Website
If you own a 99-03 7.3 PSD, this is the place to be:
Roadside Help Network
  #3 (permalink)
Old 02-03-2007, 09:33 AM
amiller93's Avatar
amiller93 amiller93 is offline
amiller93 has a good reputation on FTE.amiller93 has a good reputation on FTE.
Start with small bits and work your war up to the right size, most of the shavings will end up in you face as gravity is helping you. When you are finished drilling tak a "magnet on a stick" and stick in the hole to get the bigger stuff. When you crank all of the little stuff will be blown out the exhaust before the turbo has a chance to spin up good and wont hurt anything.
Guzzle: quit changing your title.you are wearing my latin dictionary out...LOL
  #4 (permalink)
Old 02-03-2007, 09:49 AM
hdman6 hdman6 is offline
hdman6 is gaining momentum as a positive member of FTE.
Smile
When I installed mine (4 weeks ago) I drilled the manifold from the bottom so the Thermocouple is upside down. So all the shaving kept falling out anyway. Wear safty glasses when you do this because the shaving are small. But I started with a 1/8 then went to 1/4 then used the "R" bit to finish the hole. Then when u tapp it turn the tapp a few turns in then back again to clean it out. I didnt et any shavings in my manifold this way. You can also use a vaccuum to suck out any remains if there are any. But shouldnt be hardly any. Jeff
__________________
2002 7.3 PSD Lariat Crew Cab F-350
AIS intake w/fender mod, ISSPRO 3 guage pillar, MBRP 4" SS exhaust, Bilstien shocks, Dick Cepek Fun Country II Tires, Reverse backup sensors. ARE fiberglass hartop w/airfoil, ITP overboost Kit, BTS valve body, DP-Tuner, Powerslot Rotors/Hawk Lts pads. 6.0 Tranny cooler,Warn Premium Hubs
  #5 (permalink)
Old 02-03-2007, 10:06 AM
erik_bishop erik_bishop is offline
erik_bishop is starting off with a positive reputation.
I drilled mine from the top on the drivers side manifold, seemed to have the most room to manipulate my cordless drill, i used the engine running method. took a lot longer especially when running in the tap, the air blowing out of hole kept getting too hot, and i was cutting in the threads very very slow, afraid of breaking it.
__________________
02 F-350 / XLT / 4X4 / CC / LB / 7.3
Kwik Filter, 5" Straight Piped Exhaust 6" SS TIP
Factory Tech VB,
Wicked Wheel, Dynatrac Free Spin Hubs,
DP Tuner, high idle, 40HP tow, 60HP tow, 80HP econ, 120HP
Quad Pillar, Isspros gauges, EGT, Boost, Tranny, Fuel Pressure
  #6 (permalink)
Old 02-03-2007, 10:49 AM
sean23johnson sean23johnson is offline
sean23johnson is starting off with a positive reputation.
i just moved my pyro to pre-turbo a couple weeks ago and it was nerveracking at first but is acually was very easy. i too started with a small bit and worked my way up. i also costed each drill with axle grases to grab as much shavings as possible, worked very well. i also started the truck after i tapped to let the shavings blow out and with the ammount of compression these engines have there was no way any shavings were going to stay in there. no worries, piece of cake, youll do fine.
__________________
1999.5 F250 4X4 7.3l now with a ZF6, Rough Country AAL, 4" blocks, firestone air bags, Boss gooseneck hitch, Autometer gauges, 6637, MBRP 4", ITP ported compressor housing, ITP in-tank mods, Harpooned, Riffraff FRx, PHP tunes,bellowed up-pipes
  #7 (permalink)
Old 02-03-2007, 02:20 PM
Ok, some times I amaze myself with dumbness.... never occurred to me to drill it from below! Or even to remove the bits with a magnet!!
Sometimes the learning curve can be so steep!
I will try it myself, more fun to work on it myself anyway and you know if it is done right or not.
I got a line on factory installed exhaust system so, might not tackle that one on me own.
Thanks again guys,
Dave
__________________
  #8 (permalink)
Old 02-03-2007, 04:09 PM
lovemy150's lovemy150's is offline
lovemy150's is starting off with a positive reputation.
I drilled and tapped my pyro while the engine is running. Somebody called it the hoop method. Hope this helps. BTW apply the parking brake for safety if you use this method.
__________________
99 F350 CC SRW SB
  #9 (permalink)
Old 07-27-2008, 09:10 AM
theenforcer's Avatar
theenforcer theenforcer is offline
2004 Ford F-250
theenforcer is gaining momentum as a positive member of FTE.
another way is to put some grease on the drill bit and the swarf will stick to it and not drop in the manifold
  #10 (permalink)
Old 07-27-2008, 10:04 AM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
1996 Ford F-350
My Garage
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
I was told by a guy who has installed a whole of of pyros to just drill and fuhgeddaboutit. Start small, don't use any grease (let the chips fall out), install your pyro and enjoy.
__________________
Chase
PAA Member #2
97 F350 CCLB 4x4 PSD
96 F350 CCLB 4x4 PSD - totaled 4/17/11 and sorely missed
God speed Markadeck, you will be missed
ThumperTalk / All Things Moto! / Back Country Rebels / SAWS / BRC
  #11 (permalink)
Old 07-27-2008, 07:28 PM
Pocket's Avatar
Pocket Pocket is offline
Pocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud of
Quote:
That's exactly what I did.
__________________
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's
Your connection to the Colorado diesel community.
  #12 (permalink)
Old 07-27-2008, 07:50 PM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
I did the same thing. Drill and forget.
__________________
RICK, PAA MEMBER #4
2001, F-350, DRW. CC. LWB, 4X4, LARIAT,
MODS: 6637 W/Pete's cover, BTS-TRANS, DP-TUNER LIVE, MBRP 4" SS, Isspro 3 gauge kit, TN-BB turbo, Bellowed up pipes, HPX, TRU-COOL cooler, SS Stage II injectors, and the Chris-fifty.
  #13 (permalink)
Old 07-27-2008, 07:56 PM
megawatt00's Avatar
megawatt00 megawatt00 is offline
megawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputation
Just don't that when your running the tap in, For every 1\2 turn in back out 1/4 turn. This will help prevent the tap from binding and breaking.
__________________
Jim
01 F350 DRW, Autometer Gauges, Custom CAI with Petes Cover, 6" Miter Stacks, 38R Turbo, Casserly SS Injectors, Live tuned by DP-Tuner (F6) , and a bunch of other stuff some show, and some go. PAA #14
www.roadsidehelpnetwork.org
RIP Mark.. I'll never forget you!!
  #14 (permalink)
Old 02-14-2012, 12:06 PM
racincowboy racincowboy is offline
racincowboy is gaining momentum as a positive member of FTE.
When drilling upside down like that here is a little trick I use to keep shavings from getting in my face. Take a paper cup like small dixie cup and drill through the bottom of it then slide it up near the chuck on your drill and start drilling your hole.
Then once everything is started and going well just slide your cup up the drill bit close to the hole you are drilling and it will catch most if not all the hot chips before they end up in your shirt or armpit.
__________________
Lance
99 PSD Crew Cab dually 4x4 (built 7/98), 4in straight exhaust, AFE II intake w/ petes cover, DP Tuner 40t, 60t, 80t, 80E, 120 race, OBA, CCV, 6.0 trans cooler, Isspro old school boost, pyro and trans temp., Warn Hubs
Thanks Clay@ Riff Raff Diesel Performance
WWW.pistonswild.com
  #15 (permalink)
Old 02-14-2012, 12:21 PM
CSIPSD's Avatar
CSIPSD CSIPSD is offline
CSIPSD is a name known to allCSIPSD is a name known to allCSIPSD is a name known to allCSIPSD is a name known to allCSIPSD is a name known to allCSIPSD is a name known to all
Quote:
Drill, tap, install and drive.
Unless you live somewhere that they have turned off gravity to save money, 99.9% of the shavings will fall in your face. I have done close to 60 pyro installs over the years. Never had a single issue...
__________________
01 F-250 SC, 235k,17 Isspro Gauges, AFE-2, Modded H2e, 6.0IC, 250/200 Hybrids,Studs, Forged Rods, Water injection, Swamps Tunes, 100 axl tank, 4" lift,37" TOYO MT's "
Joe
Tags
2000, 2001, 2005, 73, engine, f250, f350, ford, install, installation, pics, powerstroke, pyro, pyrometer, running
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
