02 sensor replacement - Ford Truck Enthusiasts Forums
Old 02-02-2007, 01:49 PM
rsylvstr rsylvstr is offline
rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.
My mechanic (my best friend's dad) says that sometimes the heated O2 sensors should be replaced before they go bad and start spitting codes.
anyone bother doing this?
if so, which ones, or did you replace all?
MC brand?
Old 02-02-2007, 09:57 PM
ubereal2's Avatar
ubereal2 ubereal2 is offline
ubereal2 has a great reputation on FTE.ubereal2 has a great reputation on FTE.ubereal2 has a great reputation on FTE.ubereal2 has a great reputation on FTE.
Smile
When would that be???
I also have an 01 with almost 120K, have never had to replace more than the DPFE sensor.
If it ain't broke.. Don't fix it. But I keep my maintenence up to the letter.
Bob
Old 02-02-2007, 11:18 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
O2's should be replaced at 60K miles, they can last longer. However your performance and mileage will suffer once they begin to fail. I use motorcraft now, they plug into the stock harness. I have tried some aftermarket that required splicing.
Old 02-02-2007, 11:21 PM
ReAX's Avatar
I forgot F150 have four, the post cat sensors monitor only the emissions aspect. The pre-cats talk to the ecm for engine management. You can replace the fronts and wait for the rears to fail, but it would be easier to replace them at once so you know how old they all are.
Old 02-03-2007, 10:55 AM
Quote:
are all four the same part?
any sponsors have good prices?
Old 02-03-2007, 11:47 AM
ReAX's Avatar
DY-1039 5C5Z9F472AA XC2F-9F472AA Front
DY-1093 F85Z9G444BA F75F-9G444BA F85F-9G444BA Rear
So no, front and rear have different pns.
Old 02-03-2007, 12:48 PM
Thanks ReAX....let's hope i don't have a problem getting them out...my 92 Galant is seized and i can't break her loose, even with a breaker bar and penetrant....rather just leave that one in there!
Old 02-03-2007, 02:32 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
I've found if you run the vehicle so the exhaust gets warm they can be easier to remove, also helps to spray them down with Pb blaster a few days before you plan on removing them. I try to replace mine every 60-80K, rears are $5-$10 more than fronts IIRC.
Old 02-03-2007, 04:07 PM
Quote:
another member said the same thing, i've blasted it twice and tried once warm and once HOT....no joy.
Cps therigwelder 1994.5 - 1997 7.3L Power Stroke Diesel 42 12-19-2015 10:02 PM
What sensor is mounted on the right head? gccch 2004 - 2008 F150 1 08-25-2014 01:50 PM
reverse sensor Pyancey Excursion - King of SUVs 1 01-16-2013 10:08 PM
Oil on ICP sensor aocabrown 1999 - 2003 7.3L Power Stroke Diesel 4 12-29-2007 12:08 AM
Oxygen Sensor question irishguyincc Ranger & B-Series 19 11-12-2005 09:56 AM
Tags
02, 2000, 2006, 54, 54l, 5c5z, 5c5z9f472aa, 9f472, aa, f250, f85f9g444ba, f85z9g444ba, ford, location, locations, sensor, sensors
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
