Towing with 5.4 Econ - Ford Truck Enthusiasts Forums
Old 02-02-2007, 12:15 AM
capstan capstan is offline
capstan is starting off with a positive reputation.
I recently bought a used 2003, passenger van, with the 5.4 engine to tow my boat with. It has 52,000 on it. The boat and trailer weighs about 6500, which is at or within the towing capacity, according to the owners manual. I also removed the two bench seats, since I am single, and don't need them. That removed a couple hundred pounds. I read the chapter on towing carefully, but I can't see anywhere, if I should tow in or out of overdrive. My common sense tells me to tow out of overdrive. Any suggestions. The van has a heavy duty hitch, and the tow package, and electric brakes, and was used for towing something. I bought it from a dealer.
Old 02-02-2007, 07:50 AM
RGT RGT is offline
RGT is starting off with a positive reputation.
Your insincts are correct.
For that much weight you should tow out of overdrive.
Old 02-02-2007, 10:27 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
I would think it depends on the gear ratio. If your high geared like 3.73 or 4.10, I wouldn't expect it do well in OD. If you low geared, you might try it.
If you have a trans temp guage, just keep your eye on the temp. As long as it stays in a normal range, it shouldn't hurt anything.
Old 02-03-2007, 03:27 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
On flat ground, OD is ok, but I usually leak OD iff when towing that much weight.
Old 02-06-2007, 08:34 AM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Just turn the OD off. Even on flat ground you're putting a pretty good strain on the transmission when towing your boat. The transmission will last longer if you lock out the OD while towing.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
