2000 f250 emergency brake cable problem - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 02-01-2007, 03:00 PM
96expblk 96expblk is offline
96expblk is starting off with a positive reputation.
I replaced the emergency brake cable from pedal and when I got ready to hook up to other cable under truck, it was about 2 inches too short. I can't see any adjustments to make cables meet under truck. Any suggestions?
The truck is 2000 f250 4x4 diesel. The old cable just snapped at the connection to the pedal.
Old 02-01-2007, 03:33 PM
F250_'s Avatar
F250_ F250_ is offline
F250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputation
Welcome to FTE!!
You could always use a turnbuckle style adjuster with the eye bolts on each end. Use some generic cable loops to make the eyes on each end of the cable and connect the turnbuckle to it... This setup would give you some adjustability to make sure that you got your tension correct and could keep it that way as the new cable stretches.
To keep vibration from allowing the turnbuckle to come loose, you could first take the eye bolts out of the turnbuckle housing and run a single nut up the bolt as far as it goes... do this on each end. Run your cable ends through each eyebolt. Clamp each cable closed around the eyebolt opening. Reinstall the eyebolts back into the housing. Adjust for proper tension. Tighten your two nuts down against the housing as a "jam nut". Voila... tight and stays that way. To adjust tension in the future, just loosen the jam nuts, tighten the housing on the eyebolts, and retighten the jam nuts again.
Should be able to find all the parts at Home Depot or any other hardware store (look in the rope/wire rope/cable area... everything's there).
Old 02-02-2007, 04:51 PM
emergency brake cable problem fixed
Thanks for the input. I found the problem. I feel really dumb. All I had to do was push the emergency brake pedal up with my hand and that gave me the necessary cable length needed.
Emergency Brake Cable Broke: How Fix? TomBrooklyn2 1999 to 2016 Super Duty 3 04-22-2015 02:51 AM
Need help with parking brake cable replacement!! hunter301 1999 to 2016 Super Duty 8 11-12-2014 08:58 PM
Emergency brake cable Jimbo302 1987 - 1996 F150 & Larger F-Series Trucks 9 04-02-2013 05:36 AM
parking brake cable removal brcwelding 1987 - 1996 F150 & Larger F-Series Trucks 2 10-08-2011 06:02 PM
78 F250 Crew Cab Parking Brake Cable Bouts21 Brakes, Steering, Suspension, Tires, & Wheels 1 01-06-2005 02:30 PM
Tags
02, 2000, 2002, adjust, brake, brakes, cable, emergancy, emergency, emergeny, f250, f250emergency, foot, ford, install, problems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
