Hutch mod
Hutch mod
Do you need to buy a kit for this or is it something you can throw together yourself, I found this kit online. http://www.itpdiesel.com/store.php?...ion=show_detail
Also, is this that hard of a mod for a guy to do in his driveway?
Hardest part may just be getting the tank down. You will need the quick disconnect tool too. Pretty straghtforward if you have any mechanical aptitude. Most have found the kits are a good deal rather than running around rounding up parts. Your link is the hompage, not showing the kit.
BTW, the biggest pita for me was getting that confounded threaded collar started back on at the top of the tank. My blood pressure goes up just thinking about it. The last item I was worried about.
You can try and gather up all the parts but your cost will most likely come to more that the kit that Dennis sells. It's a good kit with everything your need.
If you are mechanically inclined, it's an easy job if your tank is almost empty. A few pitfalls, search on Hutch Mod and In-tank mods and you'll have lots of reading while you're waiting for your kit to show up.
on
Originally Posted by John7894
Is that Baldwin filter overkill? Will it put additional strain on the stock fuel pump?
I'm looking to do the in tank mods soon and was thinking of just adding a small clear see through filter before the pump. What ya think?
