Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 01-31-2007, 11:03 PM
Jacksfirstdiesel Jacksfirstdiesel is offline
Garage is empty, add now
Jacksfirstdiesel is starting off with a positive reputation.
New guy some old questions
I'll make this brief. I have an '87 6.9 IDI with 2 tanks. tried running B100 in the front tank, B20 in the rear for start-up and to switch to in case it was too thick.I needed to thin it down to about B65 to keep it moving. Is it a good idea to put a heat exchanger in the system for both fuel tanks? should it be placed in front of the fuel/water seperator or where? There are some available on ebay. thanks
  #2 (permalink)
Old 01-31-2007, 11:13 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Where in CA?
B100 does not usually require "thinning" unless the temp is fairly cold.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #3 (permalink)
Old 02-01-2007, 08:25 AM
willbd willbd is offline
willbd is starting off with a positive reputation.
Quote:
Are you running strait vegetable oil in the front tank?
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
Bryan Will
  #4 (permalink)
Old 02-01-2007, 11:18 AM
No I am not running SVO. The B100 is pretty thick (like 30 wieight oil) It is also pretty cloudy. The supplier is working on improving his process and this might improve with his experience and time. So I should not have to make any modifications to fuel delivery to run Straight B100?
  #5 (permalink)
Old 02-01-2007, 11:36 AM
All of the Biodiesel I have seen is like 5 wt oil.
__________________
Bryan Will
  #6 (permalink)
Old 02-01-2007, 12:03 PM
Phydeaux88's Avatar
I dont know what it is but it doesnt sound like BD to me
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
