1985 Big Bronco Needs Help
Hi I own a 1985 full size Bronco automatic 4X4. It has been giving me problems for a while. It starts only in neutral.Engine runs good while in neutral,But Put it in gear and it start bucking, I mean the engine will power up and drop on and on,put it back in neutral and its ok, I have changed the TPS,the FPR, fuel pump,fuel filter. I thought it may have water in the fuel but found none. I get a light in the dash (EMISSIONS) could the catalitic converter be clogged? sometimes it decides to run good for a while then gets the the problrm back , its like it get power ,then loses it ,up and back again..Thanks..JB
Hi Kemicalburns.... Thank you for answering. I have not owned a ford before this since High school in 1970 ,and it was a 1950 Ford Woodie. I am not sure of the Engine and transmission size. I have the vin numbers, if I gave them to you would you be able to tell? If the Transmission was over servced,would that make it go and stop go and stop? like a bucking bronco. I am going to remove and empty the cat as soon as I go back to Tennessee and see if that helps thanks for all your Help, 1FMDU15N2FLA91811
go to the website above and read up on pulling codes. knowing what motor/tranny is in the rig is very important. when you pop the hood and see an efi setup then that will be a 5.0 (302). if it has a carb on it , more then likely its a 5.8 (351w). 85 was the first year for efi in bronco/f150s running the 5.0 engine. might need a tune up with copper plugs and new wires/ cap and rotor.
Thanks, Yes I think it is OD but I know its overdrive, I love the way the RPM GO down on the highway, Passing gear is pretty rough,not smooth, but hey ,I dont plan to drive it long didtances any more, I drove it from Miami Springs, Florida to West Point ,Tennessee about 3 years ago, then from BNA to west point at least every other month. I now use it around town, and in the woods, It ha become a farm truck. The top has solid side windows..sorry. I wont get to work on it for an ther two months,when I go back,if I dont get the lay off first..I work at AA..Thanks..JB
