Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > Pennsylvania Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Pennsylvania Chapter Join Chapter, Leader: Oldtrucknut7077
  #1 (permalink)
Old 01-31-2007, 10:28 AM
gui88ford's Avatar
gui88ford gui88ford is offline
Garage is empty, add now
gui88ford is starting off with a positive reputation.
Spark Plugs on 2001 4.6 L
Hey guys,
2001 F-150 COP...4.6 L and it's time to change the plugs...i have a miss and i'm thinking it's a cracked plug cause i have no check engin light on...anyone out there change plugs on my type motor and can give me any hints or tricks.....and how long did it take...i head from many people that they are a nightmare to do....thanks
__________________
Pennsylvania Chapter: Enjoying our little part of the world
2007 F150 XLT super cab, chrome package, 18" Chrome Clad Wheels, 285/65/18 BFG At's, 5" Step Bar, 3.73 LS, 5.4 FFV 4x4
2006 Polaris 700CC Sportsman --to many mods--
1998 Polaris Indy 650 Triple --she's a runner--
  #2 (permalink)
Old 02-01-2007, 08:20 AM
ubereal2's Avatar
ubereal2 ubereal2 is offline
1979 Ford F-150
ubereal2 is gaining momentum as a positive member of FTE.
Talking
Done several, it does get easier.
You're worst side is the passenger side bank. You will have to remove the fuel rails to do each side. You'll need an 8mm socket for those. Be careful removing and replacing fuel rails not to damage "O" rings, if you replace them or not.
You'll have to remove injectors for better access to plugs. When you are installing you're injectors, a little bit of silicone paste helps on get them to set into the heads and fuel rails.
You'll use the same 8mm socket to remove the coils. For you're back cylnder's have a couple shorter extension to get down to the pluge. One longer extension won't work there. Trust me.
Right side is easier, plugs aren't set back quite as far. So I do the hard side first.
Sorry this got kind of long.
Bob
  #3 (permalink)
Old 02-01-2007, 08:26 AM
gui88ford's Avatar
thanks for the advise....seams like a pain in the ****.....my 88 with a 302 i had done in 20 min......this seams like it's going to take 2 hrs
__________________
  #4 (permalink)
Old 02-01-2007, 08:36 AM
ubereal2's Avatar
1979 Ford F-150
I've done several. Yes it's good for a couple hours.
Bob
Tags
01, 2001, 46, 46l, blazer, chevy, crack, f150, ford, mustang, plug, plugs, remove, spark, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
