HI guys, I have a problem with my charging system and want to see what you think. My battery is 5 years old, alternator is unknown age and regulator is probably original in my restored 79. I have always noticed at idle that my headlights were dim and then would brighten with a little rpm increase. This winter its gotten worse. Slow cranking, etc. I thought my battery needed replacing. After it would start, I could watch my amp gauge (add-on) charge about 20-30 amps and then drop back to just above 0 after a minute. This week, it starts jumping around, really high then drops to nothing as I'm going down the road. Now I'm thinking regulator needs replaced. I checked battery this morning, 12.8 volts cold and 14.3 with engine running. With a little rpm boost it would go up to 15.5. Short of just changing parts out, any suggestions on what I should focus on?
Thanks, Dave
__________________
Dave,
1979 F150 4x4 390 w/C6, Edelbrock carb, cam, intake.
2000 F250 PSD, Kwik filter, AIH delete, DIY fuel pickup. Superchip, WW
1994 Explorer EB, with a twin still awaiting repair
Ohm your wiring harness that goes from the alt to the reg. It can do similar screwy things when it gets hot. That being said, I think you are right. I swapped in a gm 12SI because my system was doing weird things and the wiring was bad.
Also, search the electrical for a post by user scottfreeman titles something like "69 charging issues" In it, there is discussion about how the wiring can be shortcutted to make it work.
One source of dimming lights is a battery that is inadequate for the job. Many people put the wrong battery in. There were 3 batteries originally for 70's trucks. The R 24F, used on 300 and 302 without air conditioning, and two different R 27's.
R 27F has 70 amps of cranking power, while R 27FA has 80.
The R 24F was a smaller battery, while the R27's are the same size.
Your battery is 5 years old...that's just about the age limit. You can use a hydrometer to test the cells.
I would recommend the R 27FA for your application.
__________________ Bill / Retired Ford Parts Manager ~ 1962/1997
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003
1963 Galaxie 500XL / 1965 F100 / 2008 Fusion S / 2008 Edge SEL
For an update, my battery is an Interstate 1000 cca. The truck hasn't had much use for the last 4 years so it wouldn't surprise me if anything is worn out or corroded. The only concern I've had is that when I turn my lights on, it pulls the engine down 100-200 rpms. At idle (800) the lights are really dim. Is there any way to turn the alternator faster or somehow get more juice for less rpm?
__________________
Dave,
R27F 70 AMPS 540 Cranking amps (prolly more today, this is from the 70's book)
Yes they do have more cranking amps, I went with the older info..where the book calls it "cold" amps. The later book says just amps. I don't print these books, just type the info from them.
wow, this moved forums, finally found it. Sorry the battery is a 700cca. cleaned the battery posts last weekend. cleaned other connections last night except for ground to block. I swapped out the regulator with another one I had and all hell broke loose now. Took it for a test run and it jumped up to a 50A charge and stayed there unless I was at idle. So I put the old one back on. Then swapped the alternator, I noticed then that one of the wires (F maybe, orange terminal?) was hot and was kicking in the alternator all the time. Since the old one still smelled smoked, I put the other one in. Now this morning, it charges about 30A down the highway and drops to -20A at idle. I'm taking the alternator in to get checked today and see if they can check the battery too. I'm ready to start replacing parts until I find the problem.
__________________
Dave,
For the $$ replace your alternator with a gm. Don't think I am trying to sell you on it, but I got a 94 amp for $60, and IIRC, the voltage regulator alone was $30.
I went to the o'reilly's yesterday and had the alternator checked. It was a little weak on voltage and amp output so I bought a new one. Replaced it after work and after a little test run my amp gauge was sitting at 50. So I dropped in and bought a regulator to replace it. Everything works fine now. So I had a weak alternator and flakey regulator. Kind of a double whammy.
BTW, the regulator needs screwed down and grounded or it makes your headlights flash like a disco going down the road.
__________________
Dave,
still have a problem, I'm starting to think I have a loose connection somewhere but not sure where. I cutout the added on amp gauge so my charge wire goes right back to the solenoid. But, my lights still flicker and get dim/bright flashes. Also, when I let off the gas and hit the brakes at a stop light, my stereo amp cuts out like it loses power. Also will do this when driving on rough road. I tried to shake some wires around last night under hood and under the dash, but it won't do it in the garage. Any suggestions?
__________________
Dave,
Is the engine running correctly? If the idle is too slow, the voltage may drop too much and make the amp cut out, especially if you have a lot of elec loads on.
With the flickering problem, you noticed that grounding the regulator was very important. But it's possible that what you grounded the regulator to may be rusty or intermittent. You might want to try like the other poster said, and run another ground from the engine block or the bat - to the regulator case. This also may improve the grounding to the front sheetmetal were the headlights are grounded also.
