1994 f150 4x4 front wheel bearing nut - Ford Truck Enthusiasts Forums
Old 01-30-2007, 11:14 PM
flydubber flydubber is offline
flydubber is starting off with a positive reputation.
I purchased this pickup about a year ago. It was a ranch truck and somewhat abused. Anyway I have been getting it all fixed up and have gotten to the front-end now. I am replacing the wheel bearings and lockout hubs. The side I started on was very loose and I have it going back together. The problem I have is the wheel bearing nut it is a cupped washer with spring loaded teeth inside it and a notch to fit the spindle groove, and a nut with teeth that mate to the teeth in the cupped washer. They were on the truck with the nut first and the washer on the outside but if I install them this way it looks like the only thing holding the teeth together is the lockout hub. I need to know if this is the correct order or if there is something missing.
Old 01-30-2007, 11:18 PM
plowboy2155 plowboy2155 is offline
plowboy2155 is starting off with a positive reputation.
What kind of lock-out hubs were in the truck. Manuals, 5 cap screw auto, or 3 cap screw auto?
There are different wheel nuts.
Old 01-31-2007, 08:09 AM
1994 f150 4x4 front wheel bearing nuts
The truck has manuel lockouts.
Old 01-31-2007, 09:18 AM
Mr Alias's Avatar
Mr Alias Mr Alias is offline
Mr Alias is starting off with a positive reputation.
Look at these images and see if this helps. I guessed at your motor size at 5.0 but I dont think that matters.
http://img256.imageshack.us/my.php?i...inghubshm6.jpg
http://img523.imageshack.us/my.php?i...nghubs2tz2.jpg
Old 01-31-2007, 05:42 PM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Mine have no spring setup for my 95. I have warn hubs.
I have a spindle nut with 4 notches for the socket.
the first one that goes on has a keyway sticking out for the washer with the spindle keyway, that has holes in it. This locks the first one in place. The second one you put onto that which is just ilke the first without the protrudeing keyway and mashes the 2 together.
Then in goes my warn hub assembly, a C-clip on the center shaft, and a regular wirelike deal on the outside of the hub to keep the hub from slideing out, then on goes the cap.
Old 01-31-2007, 06:40 PM
F150xlt F150xlt is offline
F150xlt has a very good reputation on FTE.F150xlt has a very good reputation on FTE.F150xlt has a very good reputation on FTE.
Here's a picture of the manual lock nut.
The lock nut has some letters stamped on it. That side should face the spindle.
To set the bearing preload, you use the special socket with the four prongs on it. Push in and tighten the nut to 60ft. lbs. while moving the wheel back and forth to seat the bearings.
Because of the racheting teeth, as 70ft. lbs is approached, the teeth will start to slip which is normal.
Then back the nut off 180 degrees. Retighten to 15ft. lbs.
Drive the vehicle and then recheck the wheel bearing lock nut torque.
Old 01-31-2007, 08:45 PM
brown 4x4 brown 4x4 is offline
brown 4x4 is starting off with a positive reputation.
double post
Old 01-31-2007, 08:52 PM
It sounds to me like he has the racheting nut. That pic is the old and 95-96 manual hub double nut style.
I recently did a 94 with manual hubs that had the racheting nut.
Old 01-31-2007, 09:44 PM
Brown 4x4 good catch. The picture I originally posted is for a Dana 50 and 60 with manual hubs.
My service manual doesn't show the ratcheting type lock nut disassembled. I think this is the type he has.
Old 02-01-2007, 12:58 PM
Yes it is the racheting type nut and has come apart. The peices were installed backwards and maybe that is why it came apart. Anyway I have a new one and everything is fine. Thanks for the help.
4 WD front end questions JRS2 1987 - 1996 F150 & Larger F-Series Trucks 4 04-16-2015 08:10 PM
Wheel bearing locknut? big-bro 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 01-10-2014 04:55 AM
Wheel Bearing Adjustment Procedure Rocky Mountain F150 1987 - 1996 F150 & Larger F-Series Trucks 12 09-11-2012 07:55 PM
Problem removing stuck inner spindle nut davidsnook1981 1987 - 1996 F150 & Larger F-Series Trucks 31 12-23-2011 05:23 AM
front wheel bearing left side keeps becoming loose frk 1973 - 1979 F-100 & Larger F-Series Trucks 11 06-25-2002 11:24 PM
Tags
150, 1994, 1995, 4x4, 94, bearing, f150, ford, front, instaled, kit, nut, nuts, removal, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
