Go Back   Ford Truck Enthusiasts Forums > Misc. > Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners Tonneau cover, caps, racks, canopies, shells, etc.SPONSORED BY:
Click Here
  #1 (permalink)
Old 01-30-2007, 10:45 PM
onebluemcm onebluemcm is offline
Garage is empty, add now
onebluemcm is starting off with a positive reputation.
Tonneau question - most weather proof
It seems clear that tonneaus are good for fuel mileage, especially if lots of highway driving. I'm more concerned with keeping out the elements but I want a soft cover for cost reasons.
I searched back to December 2005 looking for what the most weather proof tonneau might be - no clear answer. I know soft tonneaus are not as good as hard ones, or bed caps, for keeping out the elements.
So, I put forth this question - based on your epxerience with whatever tonneau you might own, of the soft tonneau covers out there, which are the most weather proof or water tight of the bunch?
Appreciate any opinions on this one. Thanks!
  #2 (permalink)
Old 01-31-2007, 08:44 AM
kellie_truxedo kellie_truxedo is offline
kellie_truxedo is gaining momentum as a positive member of FTE.
Although no tonneau cover can claim to be 100% water proof, the Truxedo Lo Profile does an excellent job of keeping out the elements. It has weather seal on the front and rear header, weather seal along the length of the rails and weather seal on the ends of the rails. So all four sides of the cover help protect your truck bed from the elements. The cover has a lifetime warranty and is very durable.
  #3 (permalink)
Old 02-02-2007, 05:56 PM
wrobo23's Avatar
wrobo23 wrobo23 is offline
wrobo23 is gaining momentum as a positive member of FTE.
lots of posts out there.. http://www.ford-trucks.com/forums/57...-covers-2.html
that's my answer. rain/snow/sleet/whathaveyou - still looks puuuuuuuurty! (more importantly, functional)
__________________
Wisconsin FTE Chapter - Club SNL Member #8
'99 F-250 LD XLT, SC, 4x4 with 5.4L and 3.73
Leave the bowties for the little boys... Ford Trucks all the way!!!
Quote:
Originally Posted by FarmForward
You gotta wonder if this guy's parents saw each other across the table at a young age...
  #4 (permalink)
Old 02-06-2007, 09:12 AM
lostin90s lostin90s is offline
lostin90s is starting off with a positive reputation.
I have had lost of big name covers. Be fore went to hard cover. (Which suck if you want to use bed) All covers the same in weather department. But most leak at tail gate area Not much can do there. or between seal to bed . But they all do well . Some are better than others at snow load etc. just research what you need for your area and check specs good luck
  #5 (permalink)
Old 02-06-2007, 02:42 PM
SCRWDRVR's Avatar
SCRWDRVR SCRWDRVR is offline
"Obsessed"
2005 Ford F-150
My Garage
SCRWDRVR has a great reputation on FTE.SCRWDRVR has a great reputation on FTE.SCRWDRVR has a great reputation on FTE.SCRWDRVR has a great reputation on FTE.SCRWDRVR has a great reputation on FTE.SCRWDRVR has a great reputation on FTE.
I have a Extang full tilt on my truck and its not purfect but it has to rain pretty hard for me to get any water in.
Just so you know though the show mythbusters did a revisit on the gas milage thing about trucks and you gain no advantage buy putting on a tonno but you will lose if you dont and drop the tailgate.
__________________
Brian DELAWARE CHAPTER
2005 F150 Lariat Supercrew 5.4 4WD
1986 F150 XL LB I6 2WD
2008 Scion xB
  #6 (permalink)
Old 02-07-2007, 09:49 AM
wrobo23's Avatar
Quote:
i'm not sure if it's the same episode i watched, but if i recall correctly, there was a small increase in milage with a tonneau, most noticably the "air net" type. if you drop/took off the tailgate it was worse. again, that's if i remember correctly. is it worth the 200-500 (or whatever cost) to gain that little milage? depends if you want the look and functionality of it too.
__________________
  #7 (permalink)
Old 02-07-2007, 04:07 PM
SCRWDRVR's Avatar
"Obsessed"
2005 Ford F-150
My Garage
It's definitely not worth the expensive if your buying it for mileage and not function. The one I saw they revisited the tests because they said they had 100's of emails and letters that they didn't test all the possibles. What shocked me was the best mileage came from removing the gate and putting one of those nets in its place but between gate up and with a tonno the results were the same.
__________________
2008 Scion xB
  #8 (permalink)
Old 02-09-2007, 07:38 PM
boxcar1974's Avatar
boxcar1974 boxcar1974 is offline
boxcar1974 has a good reputation on FTE.boxcar1974 has a good reputation on FTE.
I agree with kellie, I have a truxedo LoProfile and it does a great job of keeing the rain out. I get a drip now and then in the corners by the tailgate other than that perfect.
Kellie, is there a replacement tailgate seal. The one mine came with was a rubber flap that completely separated fron the cover in a month. My dad baught the same cover as mine and his has a plyiable seal. I baught the cover froma dealer on eBay. Brand new direct shipped from the factory so I never got around to getting a new one because of the eBay thing.
__________________
03' F-250, XLT Sport, V10, Banks Powerpack, SVT 18x8 wheels, and Toyo Open Country A/T 285-65-18E
09' F-350, XLT, V10, Regular Cab
Michael
  #9 (permalink)
Old 02-09-2007, 08:29 PM
jorlee jorlee is offline
jorlee is gaining momentum as a positive member of FTE.
Only had water problems when I went through the car wash with my Access's. Definately recommend the trail seal, ends the water spray from the sides and bottom of the tailgate. Just the corners will let some through, but haven't had any problems with rain. Access now comes with a additional seal at the front of the box making it even more weather proof.
__________________
Jordan
2011 F250 Crew 6.2 3.73 XLT FX4 Short box Weathertech Vent visors Cloud Rider Grille insert Access Toolbox tonneau 13,xxx miles
2006 F250 6.0 4x4
Traded with 59,500 miles and a Clean OASIS
  #10 (permalink)
Old 02-12-2007, 08:09 AM
jimm66's Avatar
jimm66 jimm66 is offline
jimm66 is starting off with a positive reputation.
Trail-seal seems to work good for the tailgate.
__________________
2002 F-150 XLT supercab FX4 5.4, true blue, Westin oval bars, lo-pro, piaa horns, rancho 5k's,
husky liner mud guards, trail-seal, sirius, fire extinguisher, mag-lite, tail-gate-easy-lift, bfg at ko's, custom si-do pipes, mag. 18 " & mag tips,
garmin 660, wet-okole seat covers, putco bed rails, bed-rug, recon 3rd. brake lite, led hitch cover. kenwood-mp242 hu, pioneer speakers,
  #11 (permalink)
Old 02-12-2007, 08:17 AM
boxcar1974:
I can definitely help you with that. Give me a call at 877-878-9336 or email me at kkoletzky@shurco.com.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
