What to change to run b50 or higher in 6.9L?
Old 02-17-2007, 01:25 PM
2001gocougs's Avatar
2001gocougs
2001gocougs is offline
I am wondering if there are any changes that need to be made to a 6.9 Liter so it will dependable run B50 or higher?
Old 02-17-2007, 02:59 PM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
All that is necessary is to change the rubber fuel line pieces to synthetic lines, and be prepared to change the fuel filter in the first couple of hundred miles.
Biodiesel is a very good solvent and will clean out the "crud" in your fuel system. Biodiesel will soften up natural rubber, so these short rubber lines must be changed to Viton, or another synthetic.
Old 02-17-2007, 06:59 PM
bigredtruckmi's Avatar
bigredtruckmi
bigredtruckmi is offline
Seeing your from Washington state - in the winter months when very cold like this winter you might want to cut back on the % of bio so it won't jell.
Old 02-17-2007, 07:54 PM
CheaperJeeper's Avatar
CheaperJeeper
CheaperJeeper is offline
Where you finding B50 dude? Or are you thinking about starting to brew your own?
Did you see my post a while back about looking for a partner sto start a small brewing operation?
Old 02-18-2007, 05:01 AM
2001gocougs
I found a supplier up here in Seattle that sells B99. I mix it to about b50. There is suppose to be a commercial dealer in downtown Kent that sells it also.
I would be interested in a partnership but I am going to be moving soon.
