Oil Pressure Gauge- 2002 Tremor
I was wondering if anyone has ever had a problem with the oil pressure gauge. I only have a problem if I am on a long drive and use cruise control. When I come to a stop, like coming off an exit ramp the needle keeps bouncing. I know there is plenty of oil, but I can't figure out why it bounces around. Anyone experience this problem or is my truck possessed?
Chris
Chris
First thing to do is to get a mechanical oil pressure gauge on there and see what the real pressure is when it's idling cold, idling warm, and running (typically 2000 RPM).
Since the oil pressure "gauge" is really an oil pressure switch, anything over 7 PSI causes the gauge to read middle range, anything below 7 PSI causes it to read bottomed out on the gauge.
The sensors aren't too terribly reliable, so I'd say that was more than likely your problem, but with something like oil pressure, you always need to get a real gauge on there to see what's really happening.
