Dr. Torque Extension Bar Set, impact wrench - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-30-2007, 06:54 AM
philips philips is offline
philips is starting off with a positive reputation.
Any one over used the Dr. Torque Extension Bar Set? You get 5 colored extensions for your impact, green 65 ft/lb, yellow 80 ft/lb, blue 100 ft/lb, gray 120 ft/lb, white 140 ft/lb. Does anyone like, dislike, opinions? Thank you, Philip.
Old 02-06-2007, 01:57 PM
F250tuff's Avatar
F250tuff F250tuff is offline
F250tuff is starting off with a positive reputation.
For the price, it looks interesting. I wasn't able to find much information on this on the internet. Either this is a fairly new product, or not many people are buying them. If you buy it, let us know what you think. If it works well, there is definitely an advantage here because you can use this shaft on any size socket. That isn't the case with AccuTorq, because their socket is made into the shaft.
Old 02-06-2007, 04:36 PM
04F-250 stroked 04F-250 stroked is offline
04F-250 stroked is starting off with a positive reputation.
This may be a stupid question, but how do these differ from the standard extension.
Old 02-06-2007, 04:52 PM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
http://www.toolgopher.com/index.asp?...OD&ProdID=5829
Here is a link to a picture of the Dr. Torque extensions.
The bars are supposed to flex on each hit of the air wrench once a certain torque limit is reached, preventing you from overtightening the bolt.
Old 02-07-2007, 07:15 AM
F250tuff's Avatar
Quote:
Like Redford said, the Dr. Torque set lets you know when you have reached the torque setting. The thing I like about the AccuTorq tools is that when you reach the setting on them, they free-spin, so you can't over-torque.
Old 02-07-2007, 12:55 PM
F250tuff's Avatar
Quote:
I just found a video about AccuTorq, and I was wrong about the free-spinning. Here's a link to it if anyone is interested in seeing how it works:
http://www.asedeals.com/video_accutorq_sockets.wmv
Old 02-07-2007, 01:06 PM
PHWLEE's Avatar
PHWLEE PHWLEE is offline
PHWLEE is starting off with a positive reputation.
I've seen these impact extensions used in the local Mavis tire shop. I personally have a Snap-On digital torque wrench and trust that because it is more accurate. I guess for places that deal with the impact needs of lug removal all day, those would not be a bad choice. Since the lugs can be used to torque to within a plus or minus of the rated torque, it works for them.
Old 02-07-2007, 02:24 PM
redford's Avatar
Looks like the AccuTorq and the Dr. Torque extensions work about the same way.
OK for lug nuts but I wouldn't torque a head down with them.
Old 02-07-2007, 03:54 PM
wyoguy wyoguy is offline
wyoguy is new and has a neutral reputation at this point.
I was in the tire business for years and used them extensivly. The accu-torq are very accurate and easy to use, saves alot of time when dealing with a lot of mounts and dismounts. Using a air wrench, you tighten' the lug nut until the nut stops and it is torqued. Different lenghts and sizes for different torques. Even have on up 180lbs. for larger trucks.
However you will need to use a good air wrench with at least 250lbs. torque and have a compressor with 120psi or higher and lots of volumn to make them work properly.
What makes them work is the lenght and size of the shaft. It has been calculated to the proper torque of the particular stick.
Wish I had thought of it.
It is the same principal as using a extension on a ratchet, you lose force the longer the extension.
Old 02-07-2007, 04:10 PM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Thumbs down
Quote:
These Dr. Torque Bar set are not applicable to our SD's. The torque value is to low.
Our SD's need 150-165 ft/lbs. These only go up to the 140 ft/lb range.
Just my .02
biz
Old 02-07-2007, 05:02 PM
Accu-Torq will custom make any size you need on request, special order.
Or you can use 140, run up and finish with normal torq wrench.
Old 02-07-2007, 06:27 PM
redford's Avatar
Quote:
Originally Posted by wyoguy
..........use 140, run up and finish with normal torq wrench.
Why bother? Just run it up and finish with the torque wrench.
Old 02-07-2007, 08:59 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
A few years ago Ford sent the torque sticks to all their dealers.
We use them in our shop. We've compared the torque reading numerous times to a good torque wrench. They've always been overtorqued but even. Some of us have been using ones rated for lower torque than called for so the wheels aren't overtightened, i.e. using a 75 ft.lb. stick for wheels that are supposed to be torqued to 100.
Old 02-07-2007, 09:51 PM
F250tuff's Avatar
Here is the link for the custom AccuTorq stick for the Superduty:
http://www.accutorq.com/page4.html
I have found them on one website for $25 and free shipping.
Upper Intake Manifold Torque Specs daniele Ranger & B-Series 6 09-28-2011 04:55 PM
Superchip 1705 Specs whopp 1999 - 2003 7.3L Power Stroke Diesel 20 10-18-2008 09:23 PM
Worthless 250ft impacts to the CP Earthquake ErrorS Garage & Workshop 27 05-23-2008 03:52 AM
Granatelli mileage miser 50calmike 6.0L Power Stroke Diesel 5 09-14-2006 09:08 PM
Electric Impact wrench 04SilverSCFX4 Garage & Workshop 25 08-09-2004 09:28 PM
Tags
165, accutorq, bar, extension, extensions, ft, lb, lbs, on, snap, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
