power steering fliud in toyota box
Hi guys. In my `56 w/312 I have a `56 ford [eaton] power steering pump to be hooked up to an `80s toyota p/s box. Ford calls for type A automatic transmission fluid to be used in their p/s system. I have no idea what fluid toyota calls for in their p/s system.
Should I use type A? Should I use what Toyota calls for? Or is their a compromise?
You guys with this set-up, let me know what your sucessfully using.
Thanks. Gusso
Thanks. Gusso
Thanks, ALBUQ F-1. Your right about power steering fluid back in the `50s as I said in my post [automatic transmission fluid type A]. I guess as you said any flavor will be OK. I`m more concerned about using the wrong flavor in the old `56 eaton pump than the Toyota box. Thanks again. Gusso
....UH....er.....
I can tell you, I just can't tell you right now....
It seems like the pressure side is the one closest to the frame but until I can get home this evening and look under the hood of the old truck I won't know for sure (it would appear that the brain cells holding that info have been knocked out of commission at some point...lol)
Hopefully someone will stumble along and verify it
Bobby
Bobby
