Fuse for blend door actuator - Ford Truck Enthusiasts Forums
Old 01-29-2007, 08:43 PM
coastie-ford coastie-ford is offline
coastie-ford is starting off with a positive reputation.
Which fuse is the blend door actuator motor wired through?
Old 01-29-2007, 09:49 PM
3-RANGERS's Avatar
3-RANGERS 3-RANGERS is offline
3-RANGERS is starting off with a positive reputation.
Hi there coastie-ford and welcome to FTE. It may be that I don't understand your question but more than that I am not sure what a blend door actuator motor really is. Could you help me a little. And maybe while you are at it you could tell all of us what model and year you have as well as what you are terming as a blend door actuator motor. Thanks and Welcome Aboard ! Hope we can help.
Old 01-29-2007, 10:16 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
What year, model and manuel or EATAC control?
For manuel control there is a fuse, for EATAC there is a controller in between.
Old 01-29-2007, 10:43 PM
3-RANGERS's Avatar
Question
Ok...I know what it is now.
Old 01-31-2007, 06:44 PM
I don't know what I was thinking. It is a 2000 F150 4.2L manual trasmission.
The blend door is the door that opens and closes when you adjust the temp control.
I looked at the wiring diagram in Haynes, it looks like Fuse #5.
which fuse for blend door actuator? Gerby Dutchy 2009 - 2014 F150 0 11-16-2014 10:35 PM
Blend door actuator Geeha 1997 - 2003 F150 4 09-30-2011 10:00 PM
Blend Door Actuator location Snooze Aerostar 14 08-20-2011 02:57 PM
error codes fromt he ac headunit..now what hrdfrntr95 Explorer, Sport Trac, Mountaineer & Aviator 3 06-16-2010 09:08 PM
Explorer Blend Door Actuator Not Working blockerm Explorer, Sport Trac, Mountaineer & Aviator 1 09-04-2005 06:23 AM
Tags
01, 03, 150, 1999, 2003, actuator, blend, door, f150, ford, fuse, location, motor, number
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
