backing down ip
Old 01-29-2007, 06:44 PM
losescrew1968's Avatar
losescrew1968
losescrew1968 is offline
Smile backing down ip
hi every body. hope the new year is treating you all very well. i have a ?? for idi mech. i want to back down my ip rail pressure but can not find the right post on it. i konw it is in there but can't find it so could some one out there tell me step by step how to do it? my 1985 f350 2-4 cc puts out lots of white smoke when i mash the thortel down ont hard but easy on up LOT's OF IT.cleand cdr check air filter fuel filter replaced return lines and caps reset timing. done every thing i can think of but detune ip.
thanks for any help i can get.
ken
Old 01-29-2007, 07:48 PM
skimballc's Avatar
skimballc
skimballc is offline
Sounds like your timing's retarded or you got water getting in your cylinders. Whats your exhaust smell like?
Old 01-29-2007, 08:45 PM
losescrew1968
Talking backing down ip
there is on water in the cylinders. smelles like raw fuel. my ? was the steps on how to detune the I.P.
but thanks any way.
ken
Old 01-29-2007, 09:42 PM
KJLYPW's Avatar
KJLYPW
KJLYPW is offline
http://members.shaw.ca/k2pilot/Injec...%20article.htm is an article on turning up the IP, should work the same for down. White smoke is a symtom of unburned fuel, usually timing retarded to far, or more likely injectors are spraying, ie not poping any more. Mine always smoked until I put in a set of rebuilt injectors. Good Luck
Old 01-29-2007, 11:25 PM
Spectramac's Avatar
Spectramac
Spectramac is offline
Too much black smoke would need the pump turned down. Too much white smoke sounds like injector troubles to me too.
Old 01-29-2007, 11:58 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
Is the engine up to temp when this is happening?
What is the outside air temp when this is happening?
My vote goes to bad injectors or low cylinder temps.
Old 01-30-2007, 12:03 AM
PLC7.3's Avatar
PLC7.3
PLC7.3 is offline
reset timing
Who dunit and how would be my question.........
Old 01-30-2007, 01:00 AM
CheaperJeeper's Avatar
CheaperJeeper
CheaperJeeper is offline
When my pump timing was set at 2 degrees after TDC - 10 degrees too slow (~8 degrees BTDC is the correct setting), it did just about what you're describing. Step on it and it would smoke. Steady throttle and it would stop smoking. Letting off the throttle produced another big puff of smoke.
Reset the timing to 8 degrees BTDC and the smoking problem cleared up pretty much instantly. That is the first thing I'd check....
Old 01-30-2007, 06:17 AM
losescrew1968
Wink backing down ip
KJLYPW thanks for the info. on pump tuning.
Dave S.the engine temp is 190 deg. on a man. guage out side temp 10-50 deg.
plc7.3 i did it i have set the timming up and down timming mark weith adav. till sounds like a 7.3 and retard till sounds like a 7.3 I took the injectors out of my old engine when i did the swap old engine had a cracked block it did not smoke thanks for all the info. guys. i was told this engine smoked befor i got it ' that is why i changed the injectors and the pump from old engine
thanks agine all for the help
ken
Old 01-30-2007, 07:51 PM
KJLYPW's Avatar
KJLYPW
KJLYPW is offline
losescrew1968- turing down the IP could be the solution- you will have to forgive us IDI guy's- most of this forum is about helping others out with our own experiances! 6.9 and 7.3 engines use different pump #'s and injectors depending on the year- different flow rates and injector codes had different "pop" pressures, turbo or not. Were your pump and injectors (old engine) the same model and part dash numbers as was on your current engine?? Give us some more details so we can all learn from your situation??
Old 01-31-2007, 09:38 AM
losescrew1968
KJLYPW i don't know the # of the pump that was on this engine it was gone when i got the engine. the engine #'s i will have to get and post them. i think they are located by the oil cooler some place will have a look to day iffen the old BACK will let me!!!
thanks agian for all the help. may be some day i will get this old girl up to my parr ha ha.
ken
119er
07-18-2013 07:29 PM
hookedondiesel
11-23-2012 05:00 PM
Rocketattack
09-23-2011 05:51 PM
tuppence
11-01-2008 08:01 PM
Hamberger
01-03-2007 02:37 PM
Quick Reply: backing down ip
