51 Ford 226 Temp sending unit
I just left napa and they could not get a part number on the temp sending unit. They called the NAPA direct line and came up with a number that went to a toggle switch some how. Does anyone have this number?
Thanks Kevin
P.S. I ordered a new clutch pressure plate and throw out bearing from napa $235.00. Biwin56 the disk I had was chipped and springs all loose. Story told me to order a new one, mine was too far gone. He is turning the flywheel though.
Thanks Kevin
Kevin, found this poop in the Blue Oval Truck Parts Catalogue, don't know if it helps or not.
WATER TEMP
PART # DESCRIPTION YEAR SERIES RETAIL NOTES
SW-0128 Switch - Water Temp - 6 volt -
models with warning light 48-53 F-Series 94.95 —
SW-0129 Switch - Water Temp - 6 volt -
models with gauge 48-55 F-Series 94.95 —
SW-0108 Switch - Water Temp 56 F100, F250 76.95 —
SW-0109 Switch - Water Temp 57-62 F100, F250 7.95 —
SW-0110 Switch - Water Temp 63 F100, F250 4.95 —
SW-0111 Switch - Water Temp -
before serial number 751,001 63-66 F100, F250 9.95 —
SW-0112 Switch - Water Temp -
after serial number 751,001 66-69 F100, F250 13.95 —
SW-0113 Switch - Water Temp 70-96 F-Series 9.95 —
WATER TEMP
farmsc
06-25-2014 06:33 AM
1930 Dodge
12-11-2012 10:38 AM
jeworthington
09-07-2011 08:48 AM
Steves55
06-19-2010 07:35 AM
