1939 / 1940 hot water heater - Ford Truck Enthusiasts Forums
Old 01-29-2007, 11:53 AM
19tom40 19tom40 is offline
19tom40 is starting off with a positive reputation.
I bought a hot water heater for my 1940 car and had a new core put in and the motor rebuilt. Then someone told me that it is a truck heater. Then someone else told me that the 1939 and 1940 truck heaters have different mounting brackets.
I would like to finish restoring this heater and sell it, but I would like to make sure that I don't misrepresent it and restore it correctly.
Does anyone know the difference between the 1939 and 1940 truck heater mounting? Also I would like to know the correct color paint for each year.
Any help that you can provide will be appreciated.
Old 02-09-2007, 10:13 AM
Are the 1939 and 1940 truck fire walls the same? If so, I could restore the heater as a 1939/1940 and leave the final paint color up to the buyer.
Old 02-09-2007, 12:10 PM
Carlene's Avatar
Carlene Carlene is offline
Admom
Carlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputation
Hi Tom, welcome to FTE.
I've been trying to find my old 40/41 parts book to see if it has anything in it about the heaters. The book was packed away when we moved (apparently packed real good). I'll try another closet this weekend to see if I can find it.
The heater that came in our 1941 was black with red lettering.
Old 02-09-2007, 01:34 PM
Thanks for your reply.
I have parts catalogs and they give different prefixes for the 39, 40 and 41 heaters. The 41 heater has 3 doors and the 39 and 40 heaters have 2 doors.
I haven't been able to find any reference to the mounting brackets for the heaters.
Old 02-09-2007, 01:41 PM
Carlene's Avatar
Admom
The one I have is from 1940 or 1941 - its a parts book without prices. I will let you know by Sunday what I find out.
Old 02-11-2007, 11:27 AM
Carlene's Avatar
Admom
Tom, I found my 1941 Ford Parts book, but it only shows all the body parts and the "standard" accessories. The heater wasn't one of them.
I did notice that I was wrong on the color of the heater that was in our 1941. It was siver with a red band. Didn't realize it before, but the 1st picture in my "Cosmetics" photo gallery still had the heater in place if you want to see where it sat.
Good luck on your project and let us know how things turn out.
Old 02-14-2007, 10:29 AM
Thanks for your help Carlene. Maybe someone else will be able to help with the firewall configurations of the 39 and 40 trucks.
Old 02-14-2007, 12:04 PM
46fordtruck's Avatar
46fordtruck 46fordtruck is online now
46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.
I think the firewalls may be different between the 39 and the 40. The '39's had the battery mounted on the firewall, IIRC. The '40 had the battery mounted down on the frame rails.
Old 02-15-2007, 12:39 PM
Thanks for the reply. Now all I need to find out if the battery tray interferes with the mounting of the heater. I am assuming that the 39 firewall will be similar to the 39 car standard firewall.
1940/41 half ton cab mounts havi 1947 and Older Ford Trucks 0 02-05-2015 08:49 PM
1939 & 1940 Ford Derham Body Weapons Carriers petemcl 1947 and Older Ford Trucks 8 11-03-2014 04:33 PM
1940 FORD 3/4 Ton Stake mo44t 1947 and Older Ford Trucks 6 10-29-2005 10:15 PM
1939 Ford Truck Suspension/Frame bruce91852 1947 and Older Ford Trucks 2 05-28-2004 01:48 AM
1940 flathead ford redstone 1947 and Older Ford Trucks 8 09-20-2002 06:05 PM
Tags
1939, 1940, 1941, car, ford, heater, hot, truck, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
