Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Washington Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Washington Chapter Washington Chapter
Join Chapter, Leader: Snowbunny
  #1 (permalink)
Old 01-28-2007, 09:54 PM
HawksNest HawksNest is offline
Garage is empty, add now
HawksNest is starting off with a positive reputation.
I've got brake problems
I have a '78 E-150 stretch that I use as my mobile service truck. After I bought it, I put in 3/4 ton I beams, front springs and spring perches, 3/4 ton diff w/3:11 mid-west gears(1/2" studs), 3" 3/4 ton leafs, new perches and an air bag system. THEN after a couple of years of too high a gears, I installed a 3/4 ton diff with 9/16 wheel studs, 3:56 gears and removeable drums. also changed out the front I-beams to match (1985 I think). ANYWAY, when it is slick on the roads or even wet, the front brakes lock up and skid while it feels as though the rears aren't even working....I have to stop with my left foot on the e-brake, my left hand on the release, and my right foot on the brake pedal for the fronts. the brakes are all 100% new at the wheels, and adjusted up just fine, also got lots of e-brake. I'm planning to put a master cylinder from a '85 on there to see if it helps......any opinions or personal experiences?
  #2 (permalink)
Old 01-28-2007, 11:09 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
1969 Ford F-250
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
Make sure the brakes are fully bled, all fittings are tight, and that the brake hoses are in good shape.
You might also take a look at the proportioning valve, and the master cylinder should be changed to the correct one also.
__________________
Jared
Real trucks have the key on the left
FTE Guidelines
  #3 (permalink)
Old 01-31-2007, 10:05 PM
Placermike's Avatar
Placermike Placermike is offline
Placermike has a very good reputation on FTE.Placermike has a very good reputation on FTE.Placermike has a very good reputation on FTE.Placermike has a very good reputation on FTE.
What type of brakes do you have front and back? Ford_Six is probably on to something. You also may have front discs and rear drums. Based on the description, seems like the rear brakes are the issue.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
