VIN Tags
Old 01-28-2007, 08:14 PM
oldjag's Avatar
oldjag
oldjag is offline
VIN Tags
I've got a 77 F250 with replacement VIN tags issued by the State of California riveted on the door jamb, and on the passenger side of frame rail next to the engine. I'd like to find out what the original VIN was if possible. Did Ford put the VIN anywhere else in '77? My '79 has a tag screwed to the middle of the firewall, but the '77 has no tag or screw holes in this location.
Old 01-28-2007, 09:09 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
On the passenger side frame rail between the rad support and firewall.
also under the cab on the same side.
You may find a Buck tag or 2 wired to the frame near where the Cab & Box meet
Old 01-29-2007, 06:29 PM
highboy1975's Avatar
highboy1975
highboy1975 is offline
i found a buck tag on the front bed crossmember of a truck i used for parts.
Old 01-29-2007, 09:22 PM
oldjag's Avatar
oldjag
oldjag is offline
I found a VIN number: X25JKX87271, can anyone decode this?
Old 01-29-2007, 09:49 PM
voltson's Avatar
voltson
voltson is offline
How about this:
Results for VIN#: X25JKX87271
Model Year: 77
Series: F250 - 4x2 Super Cab Pickup
Engine: 8 Cyl, 460ci (7.5L) 4bbl
Assembly Plant: Kansas City
Transmission: No code selected
Front Axle: No code selected
Rear Axle: No code selected
Old 01-29-2007, 10:22 PM
oldjag's Avatar
oldjag
oldjag is offline
Thanks for the decode. This VIN came from the "California Replacement VIN Tag" on the door jamb. Seems to match the truck, ie it has a 460, it's a supercab etc. Not sure why the original Ford tag is missing, California says the truck is not a salvage, or recovered vehicle. Where the original tag should be located there are two about 1/4" holes in the door jamb. In '77 were the VIN tags riveted onto the door post? My '79 has a white plastic sticker with the VIN and other data printed on it on the door jamb. I can see how this could be lost, damaged etc. The '77 cab looks like it was probably stripped down and repainted inside and out, as the paint has very few signs of age or scratches.
Old 01-30-2007, 03:13 AM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Both :
Rating plate on the door
Sticker on the door jamb
http://www.clubfte.com/users/mil1ion...ruckCodes.html
Old 01-30-2007, 04:37 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Exclamation
When trucks are repainted, some guys remove the VIN plates and either lose them or can't find the correct rivets to re-install them. If for some reason the truck is either inspected by the DMV or law enforcement, a new plate will be issued.
Just on a hunch, look under the passenger seat where the springs are. Ford used to attach a copy of the build sheet there.
Rob C
25
11-06-2020 05:10 PM
Cody_1948
42
03-25-2016 09:05 AM
dbgphx
08-15-2013 04:40 AM
DyceDesign
09-24-2011 11:32 PM
rusty7983
04-09-2007 01:38 PM
Quick Reply: VIN Tags
