Got a code PO125 today?
Old 02-05-2007, 09:49 PM
Fredster's Avatar
Fredster
Fredster is offline
I have a 2000 F-150 5.4L. Got a code Po125 today. Eng. service light is on.
Autozone says it means the pcm has determined that the amount of time it took for the coolant temperture sensor to reach an input value consistent with closed loop operation was to excessive. Can anyone tell me what to check for?
Old 02-06-2007, 12:17 AM
LxMan1's Avatar
LxMan1
LxMan1 is offline
It means the engine isn't warming up fast enough. Either the thermostat isn't closing completely or the temp sensor is bad.
Old 02-06-2007, 07:37 AM
Fredster's Avatar
Fredster
Fredster is offline
Where is the temp. sensor on a 5.4? I could not find it.
Old 02-06-2007, 08:18 AM
LxMan1's Avatar
LxMan1
LxMan1 is offline
There is one sensor on the drivers side head in front of the #5 intake port. I'm not sure if this one measures coolant temp or the head temp for the gauge.
Old 02-07-2007, 07:44 AM
Fredster's Avatar
Fredster
Fredster is offline
I cleared the code without doing anything. So far it hasn't came back.
Old 02-07-2007, 08:12 AM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Perhaps the thermostat stuck open one time. Might not be a bad idea to change it just to be sure it doesn't stick again if it did. Sticking closed would be worse that sticking open.
Old 02-07-2007, 08:18 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Time for a new thermostat. Replace it now before it causes further problems of a more serious nature.
Steve
Old 02-07-2007, 08:05 PM
Fredster's Avatar
Fredster
Fredster is offline
I plan on flushing the cooling sys. soon anyway. I will change the thermostat at the same time. Thanks
7240powerstroke
1997 - 2003 F150
02-22-2015 03:42 PM
James Nelson
1997 - 2003 F150
12-20-2014 01:03 PM
FFEMT32
Modular V10 (6.8l)
05-10-2013 07:31 AM
silver05fx4
2004 - 2008 F150
09-01-2008 02:25 PM
case2273
07-17-2006 06:40 AM
Quick Reply: Got a code PO125 today?
