Darn third member
BlueOvalBoy,
I've got a question for you since it seems like you actually use your truck in rough terrain. You've got an auto right? When you get stuck between a rock and a hard place; then put it in low range, does it take a lot of RPMs to get the tires spinning? Will the engine spin up to get the RPMs you need? I've got a 2wd 6.0 tool truck and it won't climb over a curb without a running start. With the wheels up against something 5 or 6 inches high, it won't move. I give it throttle and the RPMs start coming up but it won't spin a tire or climb over the curb. Doesn't seem right, does it?
eshoaff,
Yes it's automatic and that does not seem right. I haven't tried to see what it will climb over. I am not a rock crawler, it is a 50,000 dollar piece of equipment that weigh's 7600 lbs with me in it. Parking blocks need a little bump in 2 wheel drive but in 4 low it goes over no problem.
Rock and a hard place? hmm! I did not take any pictures of the situation I was in but let's say it was so deep I couldn't get the doors open. 4 low will spin them. A little too easy. 4 high heats the transmission. I suppose I'll be getting some of those v-bar mud chains for it.
That sounds like something I see in the steel erection business. Steel importers don't always supply the strength of steel specified. It's apparent when we tighten bolts with a torque wrench. A 3/4 in. A325 (the same as grade 8)bolt should be tightened to 365 lbs torque but sometimes the steel is softer and the bolts or nuts strip and sometimes the bolts are too hard and they break. I imagine Ford gets supplied with the wrong strength steel sometimes and the things they make out of it break.
I originally thought that the problem had to do with tire size. The bigger the tires the more strain on the drive line.
