Serpentine pulley from stock Ford parts for a 351C/ 351M/400??
Has anyone tried to use stock Ford or other brand pulleys and convert a 351C/ 351M/ 400 to a serpentine belt system??? With all the newer vehicles and MILLIONS of pulleys out there I can't believe we all have to buy systems that cost $1K-2K just for having a single belt. That's almost the cost of a cheap engine!! Anyone want to experiment and come up with a system that we can all benefit from??
Craig
Craig
I have a Serpentine Pulley setup on my 434. It is a March pulley setup for 351W motor. The pulleys fit, but the alternator bracket is custom, and the alternator has to be relocated to a lower location, with the large bolt into the block instead of the head.
This is a dual belt setup, one for the alternator and water pump, the other for the PS pump. I didn't install an air conditioning compressor, but it could be done with an idler pulley.
The Windors motors with Serpentine setups all have a single belt system, and a reverse rotation water pump. There is no reverse rotation WP for a 335 series motor. That would be a good item for someone to make.
RR Water pump
SVO catalogs used to have parts for anti cavitation WP's, seals, impellers, bushings, even housings as I recall. They were for std rotation though. BUT--that kinda tells me that WP's can be disassembled and reassembled etc. I wonder if some enterprising, curious, brave individual, with a shop press has looked at pressing out a RR assembly from a W motor and looking at what it would take to press/modify it to a cleveland style? I guess the passages in the C pump might not work RR, but I have not seen where anyone has looked. First thing next Monday I'll look at it----yea right
Wp
Yep, I'm curious about that--. Been watching your 434 engine stuff. If I ever make it up that way, you better "chain er down" . Checked my 400 block on the stand---almost forgot about it, under that plastic bag. Its a D1** but dont think it was a T, poor lighting. Anyway, happiness is a 434---amoungst all the other stuff I want!
Check out the Bubba's M-Block website for the casting numbers.
What is your location?
Originally Posted by danlee
I have a Weiand WP for a 335 motor disassembled. I would be interesting to look a Windsor RR WP and compare, but I don't think that they could be made compatible.
RR pump
Somewhere, out back in the tall grass, I may have an old W RR pump. Also have a neighbor with a small shop press. Maybe if I brag on his 69 460 (.030 over) camero He will let me use his press. Also may have an old C pump down under the pine straw as well----guess I better get busy--cold weather, snakes wont be too active!!!!
I took a look at my Weiand WP today, and It looks like if you changed the impeller you could get it to pump in the reverse rotation, but the cavity inside the pump is the wrong shape and it wouldn't be very efficient.
BTW, I was going through some old OHO suppliments and they had an article about swapping a 351C impeller into a Boss 302 WP. The C impeller needed the diameter cutdown to fit in the case. So, if the shaft and bearings have not changed over the years, the 5.0 reverse rotation pump may be a donor for an impeller. BUT, then you would need to fill and shape the C case.
Originally Posted by roger dowty
question- if a guy got a reverse flow wp by error and put it on an earlier windsor with regular belt system...would it heat significantly or just have ongoing 'running hot' problems?
BigShelby
09-03-2016 06:54 AM
Buyerz
06-19-2016 09:45 AM
77 pickup
23
10-02-2015 01:45 PM
