66 slick heater core re-install
My 66 slick with a 302(replacement engine) currently does not have a heating system.
I'm about to re-install the system to include a heater core and applicable hoses.
On top of the engine, where the hoses connect, there is a male nipple out of the engine block, and another male nipple out of the water pump housing. They are approximately 4 - 5 inches apart.
Currently they connected to each other via a hose.
Taking that into account, what is the proper connection for the hoses from the engine side to the core side?
Does it matter which of the two connections on the heater core side the hoses are connected to?
Any and all input greatly appreciated.
Ronindog
Ronindog
Don't forget, you'll need an inline heater temperature control valve. The valve splices into the input heater hose, and the heater temperature control cable attaches to it. By pulling the ****, the cable will allow water to flow to the heater core. Without the valve, there's no way to shut off water to the heater core, making it a trifle warm inside the cab on a hot day.
C3UZ-18495-A Valve, Heater Temp Control (Motorcraft # YG-133)
cutlass
08-09-2012 02:55 PM
