Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-27-2007, 04:14 AM
prerunner prerunner is offline
Garage is empty, add now
prerunner is starting off with a positive reputation.
94 ranger flat spot
Alright so I have a 94 ranger 2.3l manual that has a flat spot around 2k rpms. The truck will accelerate fine most of the time but every once in a while around 2k rpms it will hit a spot where it will I guess bog the engine and slow down then get back on the power and run like normal. Does anyone know what this could be. It seems that it only happens when the truck was cold but lately I have noticed it when the truck was warm also. Any info would be helpful. Thanks in advance
__________________
1994 ford ranger 2.3l 2wd ext cab
lifted with drop down lift (for now) and 31" muds
  #2 (permalink)
Old 01-27-2007, 03:04 PM
butch h butch h is offline
2001 Cadillac Seville
butch h is starting off with a positive reputation.
I would believe a throttle position sensor problem.
  #3 (permalink)
Old 01-27-2007, 03:36 PM
If it was the throttle position sensor could this hurt performance and mpg. I do have 31" tires with 4.11 gearing and i get around 12mpg now. Does that sound about right. Also I just converted my clutch rad. fan to an electric one and wanted to know how I could set it up to come on when the truck needs it. As of right now I have to watch the gauge and when it needs it I have a switch. My truck had the problem of running to cold. After the change it runs a little warmer but if im moving the truck will not warm up to normal. Thanks for the help
__________________
  #4 (permalink)
Old 01-31-2007, 04:28 PM
So thats what everyone thinks this is. The throttle position sensor. I just want to make sure thats what this is. Thanks for the help
__________________
Tags
1994, 2004, 23, 30, change, cold, explorer, flat, ford, position, ranger, replacement, spot, throttle, tps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
