5-lug 16 inch wheels? - Ford Truck Enthusiasts Forums
Old 01-26-2007, 03:43 PM
brider brider is offline
brider is starting off with a positive reputation.
How rare are 5-lug 16 inch truck wheels, and are they compatable with modern radials?
Old 01-26-2007, 03:59 PM
airharley's Avatar
airharley airharley is offline
airharley is gaining momentum as a positive member of FTE.
Are they split rims? If so you wont find any tire dealer that will mount tires on them. They also require the use of inner tubes since the rim is split.
Old 01-26-2007, 04:25 PM
No, I don't have a set, I just recall that I THINK they exist, and was wondering if they're compatable with radials. The ones I'm thinking of are NOT split rims, not the 5-lug, anyway.
Old 01-26-2007, 09:29 PM
adharvey2 adharvey2 is offline
adharvey2 is starting off with a positive reputation.
I have been running LT235/85R16's on a '71 1/2 ton 4x4 for years - no problem. 5 lug, tubless, non split rims. It came originally with 650 16's. I used to run 700 untill they got hard to find.
BTW I have tube type RADIALS on SPLIT rims on my 600, sold and mounted by a truck tire center. So there.
Andrew
Old 01-26-2007, 11:06 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
I have a set also that came to my place on a 73 Ford half-ton 4x4. I use them for studded snow tires on my 48 F1 with 215-85R-16 tires. Normal rims, tubeless radials, 5 on 5 1/2 bolt pattern and they work just fine. So they're out there.
Jeep also used a similar rim - I have 4 - one bent in an accident, but the hub opening has an lip rolled inward so they need 1/4" spacers between the rim and the drum when used on Ford hubs.
Old 01-27-2007, 08:48 AM
jeepbut jeepbut is offline
jeepbut is starting off with a positive reputation.
The jeep wheels will work fine without spacers. The lip is for strenth due to the jeep wheel center hole being larger and closer to the lugnut holes. I have been running jeep wheels on my 77 f150 for the last 100,000 miles with no spacers. The jeep drum is flat just like the Ford and jeeps don't use spacers. The down side is the 16 inch jeep wheels have no hubcap bumps inn or out style. Thanks, Lyman.
Old 01-27-2007, 09:09 AM
Thanks, guys, so I guess Ford offered 5-lug 16" rims at least into the early 70's? That broadens my search...
Thanks!
Old 01-28-2007, 09:43 PM
Bill W's Avatar
Bill W Bill W is offline
Bill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputation
My 1966 F100 parts Truck came with 16s on it, With 235/75-16 Big O raidals I have a set of 5 with hubcaps, The spare tire is Goodyear Workhorse 700. by 16 looks new They are not split rims.
Bill W
Old 01-29-2007, 04:45 PM
Brian Brian is offline
Brian is starting off with a positive reputation.
I had a set and was going to use them on my 66 f100 4x4 but chose not to because I could not find a good tire that was recommended to mount on a 5" wide rim. Current radials will mount on them but the manufactureers have a minimum recommended width. I checked with stockton wheel about resizing them and it was cheeper to buy the set new from them.
Just because something fits does not mean it's correct.
Brian
Old 01-29-2007, 09:47 PM
Bill W: Are you saying your set of 5 is available? Maybe send me a PM if they are?
Brian, all good info, and I wll do my sizing homework. Thanks!
Old 01-29-2007, 10:26 PM
Bill W's Avatar
16s
Brider, yes they would be. but i live in Arizona, dont know if that works
8 Lug 16 Inch wheels (non split rim) 1911 Warrior 1961 - 1966 F-100 & Larger F-Series Trucks 20 02-08-2016 09:54 PM
15 INCH WHEELS TO 16 INCH WHEELS Steve2916 1973 - 1979 F-100 & Larger F-Series Trucks 6 04-04-2012 04:46 PM
Need Help with wheels. 16.5 inch wheels on 2005 f250 Timmer10 Offroad & 4x4 10 11-04-2011 02:52 PM
16 inch 5 lug wheels for 61 f350 bountyhunterjp 1961 - 1966 F-100 & Larger F-Series Trucks 0 08-28-2004 02:11 PM
16.5 inch wheel??? GreatNorthWoods 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 11-17-2002 08:58 AM
Tags
12, 16, 16in, antique, christi, corpus, ford, inch, lug, rim, rims, split, ton, truck, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
