Maryland Chapter Join Chapter, Leader: BPofMD
Motor took a crap...I 'bout crapped my pants
Old 02-05-2008, 01:35 AM
Black Cowboy's Avatar
Black Cowboy
Black Cowboy is offline
Any body know of a good shop that rebuilds diesel engines? My motor went to ***** yesterday on Rte. 50 in Annapolis. She was running fine and then all of a sudden lost oil pressure and the rest is history...along with the motor. Any good recomendations would be greatly appreciated.
Old 02-05-2008, 10:59 AM
Surge08's Avatar
Surge08
Surge08 is offline
don't know anyone off hand
Old 02-05-2008, 12:16 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,098 Likes on 998 Posts
How many miles ya have on it, Jason? How long did it run without oil pressure?
Old 02-05-2008, 07:55 PM
Black Cowboy
The motor only has 140K miles. Which is surprising because any other 7.3 diesel I've driven has been bullet proof. The truck was orginally owned by a logging company and they had to put a new motor in it. They probably ran the orginal motor into the ground and probably beat the snot outta this one too. I purchased the truck from my uncle and he only used it to haul trash/junk. However, I did get a couple of leads through people at my work that will save me some money on a new motor. Ran for approx. 10 seconds w/out oil pressure. Spun a bearing maybe???
Old 02-05-2008, 09:35 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
In 10 seconds - I doubt it. I watched these things go for 15-30 minutes with no oil at all before ceasing up....and then after cooling off, start again!
Old 02-05-2008, 09:37 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
If it doesn't turn over, something broke inside!
Old 02-06-2008, 03:47 AM
Black Cowboy
I'm pretty sure something broke inside, 'cause it'll turn over but then it'll start knocking like an SOB.
Old 02-06-2008, 10:22 AM
BPofMD's Avatar
BPofMD
BPofMD is offline
Yup, sounds like a rod.....new engine time. Was the oil pressure running low for very long...like months?
Old 02-06-2008, 11:06 AM
Surge08's Avatar
Surge08
Surge08 is offline
could be a spun bearing, was it full on oil?
Old 02-06-2008, 07:32 PM
Black Cowboy
Yep, oil level was full. I changed the oil about a month ago.
Old 02-26-2008, 11:28 PM
Tractor Boy's Avatar
Tractor Boy
Tractor Boy is offline
I'll rebuild it................... it'll give me a project and something to do
Old 02-27-2008, 08:03 PM
Black Cowboy
I'm all for it, but I was told that the 7.3 diesels can't be sleeved and therefore can't be rebuilt. If you know anything different please let me know.
Old 02-27-2008, 08:10 PM
Tractor Boy
i'll look into it for ya and get back to ya with a better answer, I may be able to bore it...........
Old 02-28-2008, 03:45 AM
Black Cowboy
Thanks man
Old 03-13-2008, 02:27 AM
immastrokinnow's Avatar
immastrokinnow
immastrokinnow is offline
a 7.3 should shut off before any real damaged is caused because of the fact its a huei. it needs oil to feed injectors. no oil, no fuel, no run. but the 7.3 cannot be sleeved. but it can be bored. check with blackwidowdiesel. they have rebuild kits and stronger rods too.
