98 4.6 swap for a 99 5.4svt supercharged? - Ford Truck Enthusiasts Forums
Old 01-24-2007, 08:23 PM
micahman micahman is offline
micahman is starting off with a positive reputation.
Question 98 4.6 swap for a 99 5.4svt supercharged?
ok got a 98 f150 4x4 with a 4.6 in it and i want to know what it will take to drop in a 99 5.4 svt supercharged motor in my ford truck? what is everything i will need to do it complete? any help is greatly appreciated.
Old 01-24-2007, 10:40 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Complete Engine, transmission, rearend, wiring harness, fuel pump. I am sure there is more I am forgetting. It is also nice to take the ECU and the cluster so the PATS system would work and you wouldn't have to specially tune your comp.. Look at $10K+ easily So for half that and a 1/50th the time you could slap a supercharger on your 4.6L and be at almost the same HP.
Best bet is to find a wrecked L that some how has all those pieces in good shape for under $10K and swap them all over. Also the '99 L engines had a recall on the intercoolers they sprung leaks fairly easily and had to be upgraded.
Old 01-25-2007, 09:58 AM
damn thats pricy i bet i could do it for atleast half that here in wisconsin. but the thought is really considered. maybe im better geting a reman engine and getting a supercharger for it. i have a 4.6 that has high miles and teh timing got all ****ed up and **** broke inside and bent valves. hate it when timing jumps... i found a cheap lightning motor with a tranny going cheap with 79k miles and thought it might be worth droping in.
Old 01-25-2007, 07:02 PM
If you can get the motor and tranny cheap it could cut the price down but there are still fuel and electrical issues as well as the weaker 8.8 rear that you have.
Old 01-25-2007, 09:14 PM
i c i think im going to scrap that idea then. too much money and time
involved.
Old 01-26-2007, 03:31 PM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.
You don't HAVE to do all of that. The 4R70W will bolt right up to the 5.4L Lightning engine,and the EEC will control that 5.4L prefectly fine when it's retuned. The 8.8" rear will handle tons of abuse-they're in many,many high-powered Mustangs without failure,so the Lightning rear really isn't needed.
Now,what you actually HAVE to have:
Complete engine
Fuel system(the lightning uses dual pumps in the tank and a different pump basket in the tank)
All of the intercooler heat exchanger components
and if you want that 4R70W to last-it'll need some upgrades,and a much better torque converter than the stocker.
That's the bare minimum that you need to do the swap.
Now,with that said-I agree with galaxie641. Get a SC kit for your 4.6L,and do the proper fuel upgrades and tuning and you'll have a ton of fun without alot of hassles.
JL
Old 01-26-2007, 04:31 PM
ok i was just looking at my options and that sounds a little more practical. my 4.6 is in need of a overhaul. thanks for the input
Old 02-04-2007, 01:06 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
The only problem is after you upgrade the 4.6L to the internal parts that the 5.4L has to handle the supercharger... that's $'s.
A stock Romeo 4.6L won't hold up to what a 5.4L Windsor Lightning motor will. Which is what the '98 has in it, a Romeo, guys?
Old 02-04-2007, 01:38 PM
'98's had both Romeo and Windsor-My truck has the Windsor version in it.
And the only difference that the Lightning 5.4L has over a N/A 5.4L are the pistons. The Lightning rods are the same garbage powdered metal toothpicks that the other 5.4L's have. Heads are the same,cams are the same.
JL
Old 02-04-2007, 02:22 PM
Krewat's Avatar
JL
And the crankshaft is the same? Steel vs. cast?
I knew about the rods - which lots of people have complained about
Old 02-04-2007, 03:40 PM
I don't think Ford even knows that answer,and you'll find conflicting info all over the place. I've been present on several teardowsn of broken Lightnings, and some had forged cranks,some did not. Years were random too,so it's not like they just stopped using them in certain models. I also know that every '97-'98 5.4L that I've seen apart had a forged crank...it seems to be kinda potluck as to which 5.4L's had it.
Besides that,there's no need in a forged crank-we're talking about a deep-skirt block modular,and I've NEVER seen a crank failure that wasn't caused by stupidity or a failure of other parts. I spin the cast crank in my Tbird to 7000 rpms on a regular basis-and I'm not the only one.
JL
wish to buy tonneau cover svt pace car WTB - Parts & other 0 10-13-2013 02:03 AM
4.6 to DOHC Supercharged 5.4 swap big_ryno 1997-2006 Expedition & Navigator 0 05-22-2009 10:27 AM
svt supercharger on a 4.6? lifted f 150 Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 10 12-07-2007 11:51 AM
supercharger for 4.6 (2004)?? topdeadcenter Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 8 10-21-2004 11:17 AM
Harley 5.4 vs. SVT 5.4 pmtcfhm Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 2 05-08-2003 03:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
