Interchangability of tilt steering column to 1973 Ranchero? Easy? - Ford Truck Enthusiasts Forums
Old 05-18-2002, 09:32 AM
bbtkd bbtkd is offline
bbtkd is starting off with a positive reputation.
Hello - I am looking to swap out the non-tilt column in my 1973 Ranchero with a tilt column. They did not come out with tilt until 1974. Anyone know for sure if a 1974 column will work in a 1973? Will other years work - and what other vehicles (LTD, Thunderbird, etc) are workable donors? Lastly - anyone swapped a column? How much work is it? How long did it take you? Thanks!
Old 05-27-2002, 03:32 PM
Supercab Supercab is offline
Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.
I'll bet that a tilt column from up to a '79 Thunderbird, Cougar,LTD II, or anouther Ranchero will swap, and be a direct bolt it, just unplug the wireing harness, and unbolt the column from the inside of the car, and at the steering box.
Old 05-27-2002, 03:44 PM
Converting to tilt column tjdad62 1973 - 1979 F-100 & Larger F-Series Trucks 18 01-02-2017 06:51 PM
Tilt column with cruise, swap or repair? Dasher400 1973 - 1979 F-100 & Larger F-Series Trucks 16 08-28-2016 09:02 PM
How hard to swap tilt to non-tilt steering column GuitarJesus 1987 - 1996 F150 & Larger F-Series Trucks 5 05-12-2016 08:33 AM
Steering Column SuperDuty93 1973 - 1979 F-100 & Larger F-Series Trucks 13 07-13-2012 09:33 PM
Steering column; stick vs. auto column highboy 74 1973 - 1979 F-100 & Larger F-Series Trucks 6 11-24-2004 07:35 PM
Tags
1973, 68, 73, 79, column, columns, econoline, ford, interchangeable, ranchero, steering, swap, tilt, year, years
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
