Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-03-2002, 05:58 PM
66ranger 66ranger is offline
Garage is empty, add now
66ranger is starting off with a positive reputation.
Cougar Ramchero?
I have a project I was thinking about trying. There is a good 78 2-dr Cougar (cheap) nearby, also a good base-type '78 Ranchero. I think the front clip from the Cougar would bolt-on swap on to the Ranchero, it looks like the same lines and would make a neat custom. The Ranchero has rusty doors, am I correct in thinking the doors, except for the glass, will be a direct swap also?? Does anyone know if the stock Ranchero wiring harness has unused plugs in it where the power window wiring from the Cougar doors would fit?? Any thoughts or hints on this project would be appreciated!
  #2 (permalink)
Old 07-05-2002, 07:30 AM
Supercab Supercab is offline
Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.
Cougar Ramchero?
You are correct about the front clip from the Cougar fitting the Ranchero, doors too using the Ranchero glass, not sure about wires for the power windows though.
I once changed a set of non power doors over to power it CAN be done, but what a pain.
If you are trying to put power doors off the Cougar onto the non power Ranchero that should work, you just may find wires for them to plug into, but if not I think you could run a couple of hot lines to the doors via the factory routeing from the Cougars wireing.
This sounds like a neat custom idea using factory stuff, I say go for it & then post some pictures!!!!!
__________________
Support FTE
  #3 (permalink)
Old 07-09-2002, 06:29 PM
beachbum58 beachbum58 is offline
beachbum58 is starting off with a positive reputation.
Cougar Ramchero?
the cougar frt.clip is a lot of work torinoclip a hole lot easier it's a basic bolt on doors with power windows and all
  #4 (permalink)
Old 07-17-2002, 05:24 PM
blu93gt blu93gt is offline
blu93gt is starting off with a positive reputation.
Cougar Ramchero?
[updated:LAST EDITED ON 17-Jul-02 AT 06:25 PM (EST)]i think the last year for the torino and the torino-ranchero was '76. the '77-'79 are LTD-based. not widely considered to be one of the better looking ranchero styles...
your ran-cougar idea seems like it should be an easy swap... all bolt-on, no fabrication. of course IMHO, a thunder-chero (ranch-bird?) would look a lot cooler!
__________________
Brad
'01 Sport-Trac
'75 Ranchero 500
'93 Mustang GT
  #5 (permalink)
Old 07-17-2002, 05:40 PM
Cougar Ramchero?
__________________
Brad
'01 Sport-Trac
'75 Ranchero 500
'93 Mustang GT
  #6 (permalink)
Old 10-31-2003, 04:10 PM
V8sRus V8sRus is offline
V8sRus is starting off with a positive reputation.
Just wondering, did you ever go ahead with this project?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
