Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-24-2007, 06:28 PM
factory594x4 is starting off with a positive reputation.
Question vac. adv.
I am putting in a new vac. adv.(the old one was torn & leaking). The directions say to use the same number of turns from the seat as the old one(the allen screw in the primary vac port), but the old one was bad and had been mis-adjusted i.e it was all the way down on the seat. So what should I set it at? It is the small vac.adv.. I know there are 3 dif. kinds. What is the dif.?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-24-2007, 11:11 PM
anybody
come on guy's, anything will help.
  #3 (permalink)
Old 01-24-2007, 11:21 PM
Torque1st's Avatar
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Actually the directions are kind of idiotic since many different spring rates and types were used in the old days. If you have a vac gage and pump you can make the settings yourself. One of those hand pumps will do the trick. Getting it close is about all you can do with a generic adjustable vacuum unit.
1971 distributor & engine specifications for the 400 without EGR:
This was the GOOD year for the 400 engine before it was smogged to death.
Distributor part #D00F-U
Centrifugal Advance Start: 0-0.5° @ 350RPM Finish: 14° @ 2275RPM
Vacuum Advance Start: 0-1° @ 5" Finish: 12.5° @ 25"
Point Dwell: 26-31°
Initial Timing: 10° BTDC, 6°BTDC California.
Vacuum given in inches of Mercury (Hg).
RPM specified as distributor RPM.
Degrees specified as distributor degrees.
Double those values for crankshaft figures:
Example: 0-0.5° @ 350RPM distributor becomes 0-1° @ 700RPM on the engine.
__________________
"Beam me up Scotty. There's no intelligent life down here..."
Eric
Tips & Tricks FAQ for 335 Series Motors
73-79 FAQ & Info
Garage Forum FAQ
For more info use PM.
  #4 (permalink)
Old 01-25-2007, 10:25 AM
beartracks's Avatar
beartracks is starting off with a positive reputation.
You can use a timing light. observe your timing with the vac. hose connected then pull it off. The difference is your vacuum advance. Just adjust for 10 to 12 degrees and see how it feels.
__________________
Bear Tracks
1977 F-100 Ranger XLT,400,C6,GV
Mod's Listed in Gallery
Click Here To Help Support FTE
  #5 (permalink)
Old 01-25-2007, 05:13 PM
Torque1st's Avatar
Posting Legend
That method depends on which vacuum source he is using.
__________________
Eric
73-79 FAQ & Info
Garage Forum FAQ
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
