Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-15-2002, 09:15 PM
Big Blue4x4 Big Blue4x4 is offline
Garage is empty, add now
Big Blue4x4 is starting off with a positive reputation.
What Size Rear End do I Have?
The rear end I have right now is out of a 1965 Ranchero with a 289 2V. It has a 3.20 or 3.25 ratio for sure. I checked it by hand. I wanted to know the ring gear size. 7.5",8", or 8.8"? Any help would be appreciated. Thanks.
Tim
79 F150 4x4 410m Built Ford Tough!(9.1:1,KB pistons,custom Comp Cams X-Treme 210/218-.508/.524,roller rockers)/c6/3.5:1 gears,4.11:1 soon, Demon 4bbl, 285/75R16 BFG Mudders on alumn. mags with New Drk. Blue paint.
65 Ranchero 170-6, 3on the tree, solid mags, New Bright Yellow paint
  #2 (permalink)
Old 04-15-2002, 10:39 PM
sauerf100s sauerf100s is offline
sauerf100s is starting off with a positive reputation.
My V-8 65 Ranchero had an 8 inch Ford. It also had a close ratio T-10 4-speed, and boy was that thing fun to drive.
__________________
Steve Sauer
  #3 (permalink)
Old 07-19-2002, 03:14 PM
lghtningstruk lghtningstruk is offline
lghtningstruk is starting off with a positive reputation.
If the back of the housing has a "bump" in it - to allow for clearance of the ring gear - it is a 9". If it is just smooth - it is most likely an 8" although some very early 9" units were smooth, but I believe that was in the late 50s.
Hope this helps
  #4 (permalink)
Old 07-20-2002, 01:54 PM
Jimbare's Avatar
Jimbare Jimbare is offline
all alone in the world
Jimbare is gaining momentum as a positive member of FTE.
does it have a rear inspection cover? if so it aint a 9 inch. the 7.5 inch was not used behind v8 engines.
__________________
jim
underated and overworked.
  #5 (permalink)
Old 07-23-2002, 12:34 PM
blu93gt blu93gt is offline
blu93gt is starting off with a positive reputation.
__________________
Brad
'01 Sport-Trac
'75 Ranchero 500
'93 Mustang GT
Tags
75, 93, 96, end, f150, ford, ranchero, rear, rearend, size, sport, trac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
