Go Back   Ford Truck Enthusiasts Forums > Ford Truck Enthusiasts Site Navigation > Site Announcements
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-24-2007, 03:08 PM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
Founder ... Stay Tuned
Garage is empty, add now
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
Welcome Rickson Truck Wheels
Do you haul heavy loads? Want tougher wheels and big-rig looks? Tired of the rapid wear on your truck's tires? Look no further than Rickson Truck Wheels...
Quote:
As owners of 3/4 and one-ton pickups, we were frustrated with both the rapid wear and poor handling characteristics of our 16" light truck tires, not to mention that they looked so small. Also, when we really loaded up the trucks, we felt that our safety was marginal…. at best. As engineers and innovators, we knew there had to be a better mousetrap. All roads pointed to the use of a 19.5" commercial truck tire on our pick-ups. We also knew that we didn’t want to use adapters. We figured that if we wanted better handling, improved tire wear, good looks, and a larger safety factor, that others must too. Frustrated at the lack of availability of such a wheel, our company was born and we set out to produce 19.5" wheels in the correct bolt patterns and hub bores for our trucks.
Rickson Truck Wheels specializes in direct bolt-up/direct replacement commercial-duty 17.5", 19.5", and 22.5" wheels and tires. With our wheel and tire packages, we use a match mounting process that duplicates the OEM’s on every assembly before it leaves their facility to ensure a vibration-free ride. With the use of our special centering jigs, our technicians duplicate the mounting method that the factory engineers use to center the wheel on the truck. Then, precision balancing ensures a smooth ride for the life of the tire. We continually work closely with the equipment manufacturers to ensure that our methods and equipment are state of the art.
Check them out at www.RicksonTruck.com and let them know you saw them on Ford-Trucks.com!
__________________
The best is yet to come....
  #2 (permalink)
Old 01-25-2007, 08:31 PM
TwelveAlpha TwelveAlpha is offline
TwelveAlpha is gaining momentum as a positive member of FTE.
Welcome, Dan, Dave, Heather, & crew!
__________________
01 F350 7.3 CC 4X LWB
AIS, GTP38R, Banks IC, Stealth, ITP reg. returns, Stage 1+ singles, FASS, BTS Tranny, ISSPRO gauges, 6.0 cooler, DPTuner, 4.56's, DR4" modified, Ricksons & MichXDE2+, NFABs
Tags
195, 225, commercial, comp, ford, rickson, ricksontruck, tires, truck, truckscom, type, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
