Ranchero axles, lincoln rear-end swap... - Ford Truck Enthusiasts Forums
Old 07-18-2002, 02:52 AM
blu93gt blu93gt is offline
blu93gt is starting off with a positive reputation.
[updated:LAST EDITED ON 18-Jul-02 AT 02:53 AM (EST)]i need to find out whether my ranchero has 28-spline axles or 31-spline.
it's a '75, came with 351W and FMX tranny. rear is a 9" with some kind of posi (trac-loc i think) and 3.89 gears. i think the gears & posi were some kind of optional "towing ready" package - but not sure since it didn't come with a hitch. the rear brakes are 10"x2.5" or something like that. factory wheels were 14".
reason i'm asking is that there's a 9" rear for sale from a '75 lincoln, complete with rear disc setup. it reportedly has a 4-link rear suspension, so i'm thinking it will swap right in - but the only way i'd be interested is if i can swap in my complete center chunk (gears & posi). i've heard that the lincoln housing is wider, AND the axles stick out farther - which means i can't just swap my axles into the linc housing along with the center chunk - i'd have to use the linc axles, which i think are 28-spline. so if mine is 28-spline, then it should work. but if mine is 31, then it won't work. wheel offset isn't a consideration, since i'll be getting different wheels anyway.
does anyone know about this swap?
i know it's easy to pull an axle and count the splines, but the ranchero is in storage across town and not in an easy position to jack up right now. does anybody know - 28 or 31?
any way to get it off the door sticker?
Old 07-25-2002, 08:09 PM
bb79ranch bb79ranch is offline
bb79ranch is starting off with a positive reputation.
I would bet that your Ranchero's axles were of the 28 spline variety. They are decently strong, and since you are running a 351w you shouldn't have a problem. The '75 Lincoln disc brake rear axle assembly has 5 on 5 inch bolt pattern while your Ranchero should have a 5 on 4.5 inch bolt pattern. Re-drilling the axles and hubs will correct this easily. Hopefully the rear axle is from a Lincoln Mark IV and not a Continental.
Todd
BB79RANCH
Old 07-26-2002, 12:47 AM
yes, it's from a mark5
thanks for the answer!
Old 07-28-2002, 10:33 AM
Jimbare's Avatar
Jimbare Jimbare is offline
all alone in the world
Jimbare is gaining momentum as a positive member of FTE.
Swapping 9" Center Section ZSK 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 06-29-2015 04:11 PM
rear axle swaps greentruck72 1973 - 1979 F-100 & Larger F-Series Trucks 6 05-20-2015 04:13 PM
9" rear decode question 71mach351 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 11-02-2014 09:21 PM
8.8 traction lock interchange bsprowl Clutch, Transmission, Differential, Axle & Transfer Case 0 08-09-2014 09:50 PM
28 or 31 splines superswamper 1973 - 1979 F-100 & Larger F-Series Trucks 26 04-25-2003 06:20 AM
Tags
1967, 75, brake, disc, end, interchange, iv, length, lincoln, mark, mustang, ranchero, rear, rearend, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
