5.0 Ranger Conversion
Old 01-24-2007, 12:55 PM
TNT4.0's Avatar
TNT4.0
TNT4.0 is offline
Hi everyone,
I'm doing some research on doing a 5.0 conversion on my 4.0 Ranger. Basically, I just want some opinions as far as the work I will have to under-take. Please see my list of questions and help me to answer them to the best of your knowledge. As you read the questions, you might think they are stupid questions. I appreciate your answers and opinions anyway for I have never done this conversion on a Ranger. Thank you in advance.
  • My Ranger is a 99. Does that mean I have to put in a 99 5.0 motor in it? Or can it be 99 and newer?
  • I've been told that if I find a 99 Explorer with a 5.0, it will be a perfect doner car with all of the excessories provided. Is there another ford similar with the 5.0? (ie. F-150...)
  • Can I use my PCU or do I have to use the PCU out of the 5.0 doner car?
  • More than likely, I will be converting from an Auto tranny to a 5 speed; but in case I don't do that conversion, will my 4.0 liter, auto tranny bolt up to the 5.0?
  • Can I use the 4.0 liter motor mounts or do I have to use the 5.0 Liter motor mounts?
I'm sure more questions will arise from me, but for now; I thank you for your input. Take care
-TNT
Old 01-24-2007, 02:40 PM
mrshorty's Avatar
mrshorty
mrshorty is offline
I'm not real familiar with the '99's, but here are the answers I know:
The 5.0 was used in many applications, but I don't know how well those applications will swap into an RBV. Unless you get something concrete from someone, I'd stay with an RBV donor. The 5.0 was used in Explorers from '96 to '01.
You'll need the PCU from the donor vehicle.
No. Also note that, in Explorers, the 5.0 versions came as AWD versions (maybe some 2WD versions). You don't say if your Ranger is 2WD or 4WD. If 4WD and you want to keep the locking transfer case with a low range, you'll need to figure out what t-case will bolt up to a 5.0 transmission and still fit within your Ranger's frame rails.
Old 01-24-2007, 06:51 PM
TNT4.0's Avatar
TNT4.0
TNT4.0 is offline
Thank you for your input
Hi there,
WoW! Thank you so much for your information. I will take this into consideration and proceed.
-TNT
Old 01-24-2007, 08:31 PM
CobraXP's Avatar
CobraXP
CobraXP is offline
Originally Posted by TNT4.0
Hi everyone,
No, you can use any 96-01 5.0 Explorer. The reason most look for an Explorer as a donor is because of the similarities between the Ranger and the Explorer. It just makes for an easier swap. Any of those years will work though.
Yes, you can use a Crown Vic, etc, but they would be 4.6 V8's (which won't fit in a Ranger easily) unless you go to an OBDI setup (pre-96). The Explorer was the only vehicle to come with the 5.0 after '95 - all the others went to 4.6's. I would recommend staying with the 5.0 and using an Explorer as a donor. The 4.6 requires A LOT of custom fabricating.
No, you will need to use a PCM that is for the 5.0. Again, the Explorer is the only vehicle you will find (from Ford) that has the 5.0 and OBDII setups.
No you can't. Also, the Explorer 5.0 PCM will only accept an auto tranny in stock setup. You can put a 5 speed in it, but you would have to use an SCT XCal2 tuner (or one comparable) to eliminate the auto settings.
You will have to change motor mounts. That is about the easiest part of the swap...
I am going to move your post to the Ranger forum as there are many users there that have done a 5.0 conversion. They can give you a lot more detail information than in the Explorer forum...
Old 01-24-2007, 10:21 PM
87ford4x4inline6's Avatar
87ford4x4inline6
87ford4x4inline6 is offline
check your other post in the ranger forum. I answered it. Also just for info any 5.0/302 will work. I have a 1980 in my 87.
Old 01-25-2007, 10:51 AM
TNT4.0's Avatar
TNT4.0
TNT4.0 is offline
Thank you .
THank you very much for the information. I tried to look for a Ranger forum but I didn't have any luck. Thank you for the help in moving it. Take care.
BigBlocker0248
30
02-18-2018 11:32 AM
Rickyrobert
2015 - 2020 F150
22
05-27-2017 03:06 PM
Blueranger91
04-22-2016 11:46 AM
mustangtj02
73
03-06-2011 09:46 PM
Quick Reply: 5.0 Ranger Conversion
