03 F150 won't engage into into 4 wheel drive - Ford Truck Enthusiasts Forums
Old 01-24-2007, 11:04 AM
lettereat lettereat is offline
lettereat is starting off with a positive reputation.
2003 F150 electric 4wd shift is acting up. Most of the time it wont shift into 4 wheel drive. I checked the 2 heavy wires at the plug, it would ramdomly light a test light. I plugged it back in and it sounded like it was shifting. I test drove it. It started out in 4wd but quickly clunked and I was back in 2wd. It would not shift into 4wd after that. Anyone had this problem or know of a test I can do to narrow down the problem. Right now I think it's the switch but dont know how to tell if it's switch, motor, or something else. The pickup has 25,000 miles and only been shifted into 4wd maybe 10 times. Of coarse it's just off of warrentee. I appreciate anyones help.
Old 01-24-2007, 11:55 AM
Wilber15 Wilber15 is offline
Wilber15 is starting off with a positive reputation.
It could be the motor on the X-case. They are known to go bad.
Old 01-24-2007, 01:50 PM
wont shift into 4wd
Is there any way to test if the motor is bad? I tried checking with a test light on the harness but am not sure exactly how the motor works, therefor not exactly sure how to check voltage. Is voltage on all the time while it's in 4wd or does it have voltage only when shifting? Does the voltage vary between wires? IE: one wire is hot when engaging, the other wire hot when disengaging? I'm assuming it's the 2 heavy wires going to the connector? I priced the motor I dont want to buy one unless I have to.
Old 01-24-2007, 06:23 PM
wont shift
What is the proper way to remove the shift motor? Do I remove the whole unit or do I just remove the motor part. Also, do I cut the grey wire that goes to the case? I appreciate anyones help
Old 01-24-2007, 11:45 PM
sprky_02 sprky_02 is offline
sprky_02 is starting off with a positive reputation.
You have to make sure the problem is at the Transfer case or the front end. When it kicks out of 4wd have someone watch the front driveshaft and torque it up to make it spin the rear tires a little bit, if the front driveshaft is turning your problem is either a vaccum problem or the shifting fork inside the front diff. as was the problem with mine, check that and post back.
Old 01-31-2007, 12:55 PM
It was the shifting fork in the front diff. Thanks for the help
'95 XMSN erratic shifting 60DRB 1987 - 1996 F150 & Larger F-Series Trucks 8 11-19-2016 12:38 PM
2002 ford f-150 5.4 4x4 question three.on.the.tree 1997 - 2003 F150 1 01-13-2016 09:20 PM
Trouble with E40D Please help MetalCowboyWilliams 1987 - 1996 F150 & Larger F-Series Trucks 8 07-18-2014 08:52 AM
Why is 4WD slow shift for ESOF when cold? abovetec 1999 to 2016 Super Duty 11 04-28-2014 07:52 AM
4x4 not working - front wheels not engaging V8SHO Offroad & 4x4 7 03-24-2014 10:41 AM
Tags
03fordtruck4wheeldrivewontwork, 2003, 4wheel, drive, engage, f150, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
