Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 01-24-2007, 07:02 AM
lgeiger13 lgeiger13 is offline
lgeiger13 is starting off with a positive reputation.
code P1451 (EVAP Emission Control System)
Just bought a 1999 F150 XLT, 4.6 engine, 100,000 miles.
I'm getting a code P1451 (EVAP Emission Control System).
To start the troubleshooting, I was thinking it would need a new gas cap but,
no luck, the light came back on. Can anyone help with this code?
Thanks .
  #2 (permalink)
Old 01-24-2007, 07:27 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of
Welcome to the forum.
I would suspect maybe a bad vent solenoid back by the tank.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #3 (permalink)
Old 01-24-2007, 09:04 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE.
The gas cap has nothing to do with this fault code.
You have an electrical circuit fault, very possibly the aforementioned vent solenoid. Check the solenoid's coil for the correct resistance value before condemning.
Steve
__________________
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #4 (permalink)
Old 01-26-2007, 08:38 AM
fastford59's Avatar
fastford59 fastford59 is offline
fastford59 is starting off with a positive reputation.
Are there any bolts broken out of your exhaust manifolds ?
__________________
if it ain't FAST,if it ain't FORD, it ain't in my yard...FF59
  #5 (permalink)
Old 01-26-2007, 11:52 PM
Quote:
What the heck does that have to do with an electrical fault code in the evap emissions subsystem?
Steve
__________________
  #6 (permalink)
Old 01-29-2007, 02:15 PM
fastford59's Avatar
because if the bolts in the manifold are gone,the computer compensates by causing a rich mixture causing this code.(I think this code is per my scanner manual,I'll go back and recheck to make sure)I had a similar situation on my '97 F150...
__________________
  #7 (permalink)
Old 01-30-2007, 07:54 AM
LxMan1's Avatar
An exhaust leak wouldn't effect the gas tank vent valve solenoid.
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #8 (permalink)
Old 01-30-2007, 09:44 AM
Completely unrelated unless, by sheer coincidence, the exhaust failure damaged the wiring specific to the vent solenoid.....pretty long odds on that. You likely had a different code and set of circumstances.
The exhaust misture also has nothing to do with the electrical circuit for the canister vent solenoid. This is a purely electrical problem at this point, at least until the source of the electrical fault is identified.
Steve
__________________
  #9 (permalink)
Old 02-24-2007, 09:44 PM
Gevans17 Gevans17 is offline
Gevans17 is gaining momentum as a positive member of FTE.
P1451 EVAP Control System Canister Vent Solenoid Circuit Malfunction
  #10 (permalink)
Old 07-25-2007, 03:28 PM
Ok, over the weekend I was tring to work on this problem. I did buy a new Vent solenoid for the EVAP canister and reset the CPU. The light stayed off for about 5mile but as soon as I turned the truck off and then back on the light came back on..
Can it be the canister itself and can I clean it or fix it?
  #11 (permalink)
Old 07-25-2007, 06:45 PM
Did anyone mention this is an ELECTRICAL fault?
Steve
__________________
  #12 (permalink)
Old 06-05-2008, 01:47 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD BURNSTOUGHFORD is offline
1999 Ford F-150
BURNSTOUGHFORD is starting off with a positive reputation.
Sorry for bringing up such an old post... I have had this code for several months, i clear it every time i get into the truck and the light goes away untill the next time i start it....Is there any common problem with these or are they pretty hit and miss...
Burns
__________________
99' F-150 Super Cab Step Side
5.4l/4R70W (previously a 4.6l romeo)
CAI,Flowmaster 50 series dual exhaust,Gryphon Tuner with custom tunes (300 bhp est)
900LB AAL, cranked front Torsion Bars =(2in lift)Lariat LE Seats, Alpine cd player/6x9 speakers
2003 Fx4 Rims, 255/75/17 BFG MT KM
  #13 (permalink)
Old 06-05-2008, 05:43 AM
help you
Hey that is cool. It was (EVAP Control System Canister Vent Solenoid Circuit Malfunction). The problem was a bad wire that came off the vent solenoid. If you go to the back of the truck and look under the bed between the frame right if front is the spare tire you should see the EVAP canister. On top was the vent solenoid for the canister. If you check the wires that go from the solenoid to the wire harness one of them may be cracked, or split. Yes it was that easy but, I did find that after I got a new solenoid and canister... good luck...
  #14 (permalink)
Old 07-04-2008, 10:58 PM
w4dd w4dd is offline
w4dd is starting off with a positive reputation.
lgeiger13 from the previous post was right on !.
I had a check engine light appear on my 2000 Ford Ranger (142K miles). Disconnecting the battery did not clear it. Both Autozone and Midas read the code (P1451) and said it was the Gas Cap. Went to the Ford garage to get an original ($25) but the code did not clear. Did some searching on the net and ran across the lgeiger13 post. Slid under the truck and just in from of the spare tire is the canister and on the front top side of that is the solenoid. Traced the wires back a few inches across the top of the canister and it was immediately obvious they were damaged. Apparently these wires rub on the bracket for the canister and it had worn through the protective tubing and broken the wires in serveral places. Poor design. Used a few inches of wire, solder, some heat shrink tubing, electrical tape, and "split loom tubing (3/8 inch I think). That did the trick. I also re-routed the wires away from the bracket. My guess is just about every Ranger will have this problom eventually.
Thanks for the post lgeiger13.
  #15 (permalink)
Old 04-23-2009, 04:22 PM
finally free finally free is offline
finally free is starting off with a positive reputation.
i have a 1998 ranger that gets terrible gas milage but anyways i found ' thanks to you guys' my cables were damaged too just above the shock rear drivers side fixing it tomorow will let you know if it clears my p1451 code that ive had for 1 year thanks again
Tags
2000 , 97 , canister , circuit , code , control , evap , f150 , ford , location , p1451 , solenoid , system , trouble , vent
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
