Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 04-27-2009, 09:45 PM
jondoze jondoze is offline
jondoze is starting off with a positive reputation.
Must be an epidemic...... Same thing happened to me, 1 wire to EVAP solenoid completely split, the other 1/2 way there. Cut/crimped/spliced/wrapped and 150 miles later no light. Thanks lgeiger13
  #17 (permalink)
Old 05-02-2009, 12:16 PM
bdeyoung bdeyoung is offline
bdeyoung is starting off with a positive reputation.
thanks
pleiger and another person THANK YOU!!
the p1451 code on my expedition was exactly what and where you said it would be, frayed wire by the canister, I belie you saved me a couple hiundred dollars!!
  #18 (permalink)
Old 06-20-2009, 11:04 AM
ranger 319 ranger 319 is offline
ranger 319 is starting off with a positive reputation.
P1451 and P0457
On my 2003 F150 I had a P0457. I got rid of that with a new gas cap. I still have a P1451 so I need to check the CVS for continuity. How many Ohms should it read and whats the best way to test that? My CVS is under the hood, bolted to the fire wall, very easy to get at. I've check the hoses front to back, no problems.
  #19 (permalink)
Old 06-20-2009, 01:18 PM
Cvs
The more I read, the more confused I become, is the solenoid under the hood or back by the fuel tank?
  #20 (permalink)
Old 06-20-2009, 04:24 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE.
Quote:
The CVS is mounted on the charcoal canister above the spare tire. You're confusing it with the VMV (Vapor Management Valve) on the firewall.
__________________
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #21 (permalink)
Old 06-21-2009, 11:37 AM
Thank you! Now I just have to figure out how to get it down from there and check it. Thanks again
  #22 (permalink)
Old 06-22-2009, 12:13 PM
Where can I buy a canister vent solenoid? Looking online, all I find are the Vapor Solenoids on the firewall.
  #23 (permalink)
Old 06-22-2009, 08:41 PM
Gee, most people would check their dealer's parts department...
__________________
  #24 (permalink)
Old 06-24-2009, 02:13 AM
JJ98 JJ98 is offline
1998 Ford F-150
JJ98 is starting off with a positive reputation.
you could remove the cansters as one and check for cracks around the edge it should four bolts them just slide it out you will see once you get it i think it goes forwod and then down
  #25 (permalink)
Old 06-27-2009, 08:59 AM
Gee....
Being that I'm not a mechanic, and this is all new to me, I take it you meant to say "It's a dealer item only".
  #26 (permalink)
Old 07-11-2009, 01:58 PM
P1451
Finally got it! Traced all the wiring from front to back, checked all the fuses, tested the Vapor Solenoid, and checked for kinks or blockage in the hoses. When I got the Canister Vent Solenoid off, it look pretty bad. Tested it and found it was bad, replaced it and now the check engine light has been off for a week. Also, got it to pass echeck .Thanks to all you guys for your help!!!!
RL
Tags
2000 , 97 , canister , circuit , code , control , evap , f150 , ford , location , p1451 , solenoid , system , trouble , vent
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
