1973 ranchero swapping with 1978 302 engine
Old 05-15-2004, 08:14 PM
ranchero73's Avatar
ranchero73
ranchero73 is offline
I'm taking a rebuilt 302 from a 1978 ranchero and sticking it into a 73', the problem is the electrical harnesses for the distributors are different, what can i do?
Old 05-15-2004, 11:40 PM
grclark351's Avatar
grclark351
grclark351 is offline
can you take the wiring and brain box from the 78? or you can keep the point distributor from the 73, or put a pointless conversion module in the 73 dizzy, or get a complete aftermarket dizzy. crane has a new dizzy out, and they also make a module. MSD dizzy's are top of the line. mallory makes dizzy's and modules also. lots of options. if you pull the wiring out of the 78, you have to hook up to the ignition switch. duraspark uses two power supply wires to the box, a red and a white wire. one is for spark during cranking and the other is for run. can't remember which is which?
rmr1r
01-27-2013 09:59 PM
danlee
06-17-2008 06:10 AM
Kongslibakken
09-10-2005 02:06 AM
rancherodave
05-20-2004 08:38 AM
roybb
12-19-2000 08:52 PM
Quick Reply: 1973 ranchero swapping with 1978 302 engine
