Advice on 2.9l engine rebuild - Page 2 - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 01-31-2007, 09:33 PM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
Yep, swept volume over compressed volume. I would say that the 2.8L probably has much larger combustion chambers than the 2.9L.
Old 02-03-2007, 08:56 AM
dirtybroncoii dirtybroncoii is offline
dirtybroncoii is starting off with a positive reputation.
[QUOTE=rusty70f100]No, you cant. They widened the oil pan rails when they went to the 4.0L. It would not clear.
I Have a 2.8 block on an engine stand in my garage right now WITH a 4.0 crank in it. there is hardly any block indexing to do (for the crank)
Also 2.8 head intake runners wont line up with a 2.9 intake.
Old 02-03-2007, 07:15 PM
kernel-panic's Avatar
kernel-panic kernel-panic is offline
kernel-panic is starting off with a positive reputation.
Quote:
That's because the middle cylinders are laid out opposite between the 2.8 and 2.9. The exhaust manifolds aren't interchangeable either. Nor the cams, as far as I know, as the 2.8s have gears and the cam spins the opposite direction. There are only a few interchangeable parts between the two engines, internally or externally.
Old 02-03-2007, 08:41 PM
frankenbroncoII frankenbroncoII is offline
frankenbroncoII is starting off with a positive reputation.
just 1 question, why would you want to build up a 2.9L? would it not be more cost effective to go with a 4.0 and build it up. for the about the same money with bigger gains. just going with a 4.0 gives 30 hp alone over the 2.9. that is if your wanting to stay with a v6 class.. or for even bigger gains going 5.0 or larger v8. i know some do things just to be different and i get that. im that way myself from time to time. but sometimes it can just cost alot of cash to be different. i by no means am downing any one here. i was just courious.
Old 02-04-2007, 06:47 AM
Because to do a 4.0L swap the right way, you're going to end up spending about the same amount of money as rebuilding a 2.9!
Old 02-05-2007, 10:19 AM
OSin86 OSin86 is offline
OSin86 is starting off with a positive reputation.
Quote:
Same money and ahead with the 4.0, sounds like a good deal.
Old 02-05-2007, 11:40 AM
That's a 2.8L block. Must be a difference. This goes against everything I've seen and read on the subject.
OBTW, how much is it going to cost in dyno time to get the speed-density computer corrected with a 2.9L? I assume you'd do some changes in the rebuild, like cam, heads, etc.
Edit:
Is that a 4.0L crank in a 2.8L block with crank, rods, and pistons, or just the crank?
Old 02-05-2007, 10:18 PM
Quote:
The 4.0 puts out 250+ HP stock?
Old 02-05-2007, 10:37 PM
stock 2.9 is 140hp 170 FTLBs of torque stock 4.0 OHV is 170 hp 200 FTLBs of torque.
i just see more totential gains from the 4.0 over the 2.9. not saying the 2.9 cant be built up, bc it has and can be. but for the money the 4.0 can give more on the long end than the 2.9 with out the design flaws, though 4.0 has its own problems as well.
Old 02-05-2007, 10:47 PM
Well, money-wise, mildly (re) building a 2.9 and doing a 4.0 -stock- engine swap is about the same, if you're going to do it right. The only detracting and limiting factor on the 2.9 buildup is getting a set of the "new" WP bare heads or complete heads ($600+ for a pair). The other thing is finding ... let's see... what years of the Ranger / Explorer for "the perfect donor" ... 90-92? I'd have to find that info. Otherwise... Yeah... good luck on that!
Also, even with a little (comparatively speaking) investment, you can boost the output of a 2.9 without dismantling the engine whatsoever... to at least if not over stock 4.0 numbers.
Old 02-06-2007, 06:03 PM
LMAO, good luck getting 250+ HP out of a 2.9 without a boat load of cash!!! You'll spend WAY more on a 2.9 getting 250hp then you will out of a 4.0.
Old 02-06-2007, 07:15 PM
cdncowboy's Avatar
cdncowboy cdncowboy is offline
cdncowboy is gaining momentum as a positive member of FTE.
I never said anything about getting 250hp out of a 2.9 i just mentioned getting it close to a stock 4.0l which is 200 hp plus the 4.0l have there own issues as well and if your gonna go 4.0l you might as well go 5.0l ho it only costs a little bit more than a 4.0l swap plus upgrades
  #28
Old 02-06-2007, 07:24 PM
To me, I guess it depends on how you shop for certain parts. s/250/230, by the way. 24lb injectors and the right parts will get you to or close to 230hp, from either engine, under the right circumstances. Biggest $$$ ticket items would be the top end items (cam, heads, valvetrain), the right exhaust (including headers) and tsperformance chip. A lot of the costly things can be done by the do-it-yourselfer, i.e., porting and polishing, etc., if you have the tools / equipment (or access to them) and a lot of patience. I am sort of curious about 2.8 flat-top pistons working in a 2.9, though. I'm wondering if the tops of the pistons will need at least relief cuts so the valves don't get demolished. I'm also curious if you can run a 4.0 on a MAP system or a converted MAP system vice the stock 4.0 computer. I've seen MAF conversions and other various and sundry mods for the 2.9, including a 5.0 throttle body conversion.
  #29
Old 02-07-2007, 06:00 PM
Quote:
Wasn't really quoting you...................
  #30
Old 02-07-2007, 09:05 PM
I didn't even see that post, after I had posted my last one. Too funny....
looking for a good 2.9L for myou bronco 2 b2yan 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 1 03-09-2016 08:02 AM
2.9L v6 rods mramelbass Ranger & B-Series 5 03-10-2011 07:48 PM
Performance increase on a 2.9? jn2630 Ranger & B-Series 5 03-07-2007 11:21 PM
2.9 cologne inlet manifold 28mjg84 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 12 02-06-2005 02:27 PM
compression too high on 2.9l ? woodranger Ranger & B-Series 3 04-30-2004 09:10 PM
Tags
29l, 35l, bronco, chevy, colorado, engine, ford, gasket, hard, head, ii, newrebuilt, rebuild, rebuilding, rebuilt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
